5930 Discussions
telnet <ip address> 30 unseccessful
hi,
I am sorry to have so many questions to ask,I have try by myself for a long time,and there is nobody go for this kind of job aroud me~
the niosII console:
InterNiche Portable TCP/IP, v3.1
Copyright 1996-2008 by InterNiche Technologies. All rights reserved.
prep_tse_mac 0
Your Ethernet MAC address is 00:07:ed:ff:8f:11
Static IP Address is 192.168.1.234
prepped 1 interface, initializing...
[tse_mac_init]
INFO : TSE MAC 0 found at address 0x02102000
INFO : PHY National DP83848C found at PHY address 0x01 of MAC Group[0]
INFO : PHY[0.0] - Automatically mapped to tse_mac_device[0]
INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link...
INFO : PHY[0.0] - Auto-Negotiation PASSED
INFO : PHY[0.0] - Checking link...
INFO : PHY[0.0] - Link established
INFO : PHY[0.0] - Speed = 100, Duplex = Full
OK, x=0, CMD_CONFIG=0x00000000
MAC post-initialization: CMD_CONFIG=0x04000203
[tse_sgdma_read_init] RX descriptor chain desc (1 depth) created
mctest init called
IP address of et1 : 192.168.1.234
Created "Inet main" task (Prio: 2)
Created "clock tick" task (Prio: 3)
Simple Socket Server starting up
[sss_task] Simple Socket Server listening on port 30
Created "simple socket server" task (Prio: 4)
then i input "telnet <ip address> 30 " in quartusii shell:
&#27491;&#22312;&#36830;&#25509;&#21040;30...&#19981;&#33021;&#25171;&#24320;&#21040;&#20027;&#26426;&#30340;&#36830;&#25509;&#65292; &#22312;&#31471;&#21475; 23: &#36830;&#25509;&#22833;&#36133;
what should I do ??
thanks a lot!~
--- Quote Start ---
--- Quote End ---
Why in Quartus shell? You should type it in the OS command prompt.
Or your can connect with any telnet client, for example Hyperterminal.
However I can't understand the following Chinese characters: is this an error message or anything relevant?
Cris
hi,Cris
thank you very much for your reply,I am sorry that I forgot to traslate Chinese to English:p
yes,you guessed right,they are error messages,means:
Wrong message is being connected to the 30 ... can not open a connection to the host, on port 23: connection failed
then,I try hyperterminal, and the connection is established successfully,I am very happy though it is a piece of cake for others:-P
