hi,
I am sorry to have so many questions to ask,I have try by myself for a long time,and there is nobody go for this kind of job aroud me~ the niosII console: InterNiche Portable TCP/IP, v3.1 Copyright 1996-2008 by InterNiche Technologies. All rights reserved. prep_tse_mac 0 Your Ethernet MAC address is 00:07:ed:ff:8f:11 Static IP Address is 192.168.1.234 prepped 1 interface, initializing... [tse_mac_init] INFO : TSE MAC 0 found at address 0x02102000 INFO : PHY National DP83848C found at PHY address 0x01 of MAC Group[0] INFO : PHY[0.0] - Automatically mapped to tse_mac_device[0] INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link... INFO : PHY[0.0] - Auto-Negotiation PASSED INFO : PHY[0.0] - Checking link... INFO : PHY[0.0] - Link established INFO : PHY[0.0] - Speed = 100, Duplex = Full OK, x=0, CMD_CONFIG=0x00000000 MAC post-initialization: CMD_CONFIG=0x04000203 [tse_sgdma_read_init] RX descriptor chain desc (1 depth) created mctest init called IP address of et1 : 192.168.1.234 Created "Inet main" task (Prio: 2) Created "clock tick" task (Prio: 3) Simple Socket Server starting up [sss_task] Simple Socket Server listening on port 30 Created "simple socket server" task (Prio: 4) then i input "telnet <ip address> 30 " in quartusii shell: 正在连接到30...不能打开到主机的连接, 在端口 23: 连接失败 what should I do ?? thanks a lot!~Link Copied
--- Quote Start --- then i input "telnet <ip address> 30 " in quartusii shell: --- Quote End --- Why in Quartus shell? You should type it in the OS command prompt. Or your can connect with any telnet client, for example Hyperterminal. However I can't understand the following Chinese characters: is this an error message or anything relevant? Regards Cris
hi,Cris
thank you very much for your reply,I am sorry that I forgot to traslate Chinese to English:p yes,you guessed right,they are error messages,means: Wrong message is being connected to the 30 ... can not open a connection to the host, on port 23: connection failed then,I try hyperterminal, and the connection is established successfully,I am very happy though it is a piece of cake for others:-P Regards
