5930 Discussions
the problem about sector and chip earse time of flash S29AL032D?
in the altera fpga starter developmet kit, the flash is S29AL032D,the time request like following:
Sector Erase Time 0.7 s
Chip Erase Time 45 s
but in the example, the Sector Erase Time is set to about 25.6ms, Chip Erase Time is set to 102.4ms, the result is nice, the kit works well.
I am confused about this, anybody help me? thank you.
the code of example:
//Legal Notice: (C)2006 Altera Corporation. All rights reserved. Your
//use of Altera Corporation's design tools, logic functions and other
//software and tools, and its AMPP partner logic functions, and any
//output files any of the foregoing (including device programming or
//simulation files), and any associated documentation or information are
//expressly subject to the terms and conditions of the Altera Program
//License Subscription Agreement or other applicable license agreement,
//including, without limitation, that your use is for the sole purpose
//of programming logic devices manufactured by Altera and sold by Altera
//or its authorized distributors. Please refer to the applicable
//agreement for further details.
module Flash_Controller( // Control Interface
oDATA,iDATA,iADDR,iCMD,
oReady,iStart,iCLK,iRST_n,
// Flash Interface
FL_DQ,FL_ADDR,FL_WE_n,FL_CE_n,FL_OE_n,FL_RST_n);
///////////// Control Interface ////////////////////////
input [21:0] iADDR;
input [7:0] iDATA;
input [2:0] iCMD;
input iStart,iCLK,iRST_n;
output reg [7:0] oDATA;
output oReady;
///////////// Flash Interface ////////////////////////
output reg [21:0] FL_ADDR;
inout [7:0] FL_DQ;
output FL_OE_n,FL_CE_n,FL_WE_n,FL_RST_n;
///////////// Internal Register ////////////////////////
reg [21:0] Cont_Finish,CMD_Period;
reg [7:0] mDATA;
reg [10:0] Cont_DIV,WE_CLK_Delay,Start_Delay;
reg [3:0] ST;
reg mCLK,mStart,preStart,pre_mCLK,mACT;
reg mFinish;
reg [2:0] r_CMD;
reg [21:0] r_ADDR;
reg [7:0] r_DATA;
///////////// Internal Wire ////////////////////////////
wire WE_CLK;
`include "Flash_Command.h"
///////////// Flash Command Period ////////////////////
parameter PER_READ = 1; // 160 ns
parameter PER_WRITE = 5; // 800 ns
parameter PER_BLK_ERA = 160000; // 25.6 ms
parameter PER_SEC_ERA = 160000; // 25.6 ms
parameter PER_CHP_ERA = 640000; // 102.4 ms
parameter PER_ENTRY_ID = 4; // 480 ns
parameter PER_RESET = 1; // 160 ns
////////////// Flash State Machine ////////////////////
parameter IDEL = 0;
parameter P1 = 1;
parameter P2 = 2;
parameter P3 = 3;
parameter P4 = 4;
parameter P5 = 5;
parameter P3_PRG = 6;
parameter P3_DEV = 7;
parameter P4_PRG = 8;
parameter P6_BLK_ERA= 9;
parameter P6_SEC_ERA= 10;
parameter P6_CHP_ERA= 11;
parameter READ = 12;
parameter RESET = 13;
//////////////// Clcok Setting /////////////////////
//parameter CLK_Divide = 4;
parameter CLK_Divide = 8;
//parameter CLK_Divide = 16;
//// FL_OE_n ? Write = 1 : Read = 0 /////
//// FL_CE_n ? IDEL = 1 : ACTIVE = 0 /////
//// FL_RST_n ? ON = 1 : RESET = 0 /////
assign FL_DQ = FL_OE_n ? mDATA : 8'bzzzzzzzz ;
assign FL_OE_n = (ST == READ) ? 1'b0 : 1'b1 ;
assign FL_CE_n = (ST == IDEL) ? 1'b1 : 1'b0 ;
assign FL_WE_n = (ST == IDEL) ? 1'b1 :
(ST == READ) ? 1'b1 : WE_CLK;
assign FL_RST_n = (ST == RESET) ? 1'b0 : 1'b1 ;
assign oReady = mStart ? 1'b0 : mFinish;
////////// Flash State & WE Clock Generator /////////
always@(posedge iCLK or negedge iRST_n)
begin
if(!iRST_n)
begin
Cont_DIV <=0;
mCLK <=0;
end
else
begin
Cont_DIV <=Cont_DIV+1;
mCLK <=Cont_DIV[CLK_Divide>>2];
end
end
////////////// WE Clock Generator ////////////////
begin
if(!iRST_n)
WE_CLK_Delay<=0;
else
WE_CLK_Delay<={WE_CLK_Delay[9:0],Cont_DIV[CLK_Divide>>2]};
end
assign WE_CLK = (CLK_Divide == 4) ? ~WE_CLK_Delay[3] :
(CLK_Divide == 8) ? ~WE_CLK_Delay[4] :
~WE_CLK_Delay[10] ;
/////////// Input Signal & Data Latch ////////////////
begin
if(!iRST_n)
begin
mStart <=0;
Start_Delay <=0;
preStart <=0;
pre_mCLK <=0;
mACT <=0;
end
else
begin
//////// State Active Detect //////////
if({pre_mCLK,mCLK}==2'b01)
mACT<=1;
else
mACT<=0;
pre_mCLK<=mCLK;
if({preStart,iStart}==2'b01)
begin
mStart <=1'b1;
Start_Delay <=8'h00;
r_CMD<=iCMD;
r_ADDR<=iADDR;
r_DATA<=iDATA;
end
else
begin
if(Start_Delay<CLK_Divide)
Start_Delay<=Start_Delay+1;
else
mStart<=1'b0;
end
preStart<=iStart;
end
end
///////////// Flash Output Latch ////////////////////
begin
if(!iRST_n)
oDATA<=0;
else
if( mACT && (ST==READ))
oDATA<=FL_DQ;
end
////////////// Flash State Control ////////////////
begin
if(!iRST_n)
ST<=IDEL;
else
begin
if(mACT) // State Active Flag
begin
if(mStart)
begin
case(r_CMD)
CMD_READ : ST<=READ;
CMD_WRITE : ST<=P1;
CMD_BLK_ERA : ST<=P1;
CMD_SEC_ERA : ST<=P1;
CMD_CHP_ERA : ST<=P1;
CMD_ENTRY_ID: ST<=P1;
CMD_RESET : ST<=RESET;
endcase
end
else
begin
case(ST)
IDEL: ST <= IDEL;
P1: ST <= P2;
P2: begin
case(r_CMD)
CMD_WRITE : ST <= P3_PRG;
CMD_ENTRY_ID: ST <= P3_DEV;
default : ST <= P3;
endcase
end
P3: ST <= P4;
P4: ST <= P5;
P5: begin
case(r_CMD)
CMD_BLK_ERA : ST <= P6_BLK_ERA;
CMD_SEC_ERA : ST <= P6_SEC_ERA;
CMD_CHP_ERA : ST <= P6_CHP_ERA;
endcase
end
P3_PRG: ST <= P4_PRG;
P3_DEV: ST <= IDEL;
P4_PRG: ST <= IDEL;
P6_BLK_ERA: ST <= IDEL;
P6_SEC_ERA: ST <= IDEL;
P6_CHP_ERA: ST <= IDEL;
READ: ST <= IDEL;
RESET: ST <= IDEL;
endcase
end
end
end
end
////////////// Output Finish Control ////////////////
begin
if(!iRST_n)
begin
mFinish<=0;
Cont_Finish<=0;
end
else
begin
begin
if(mStart)
begin
mFinish <=1'b0;
Cont_Finish <=0;
end
else
begin
if(Cont_Finish < CMD_Period)
Cont_Finish <= Cont_Finish+1;
else
mFinish <= 1'b1;
end
end
end
end
////////////// Command Period LUT ////////////////////
always@(posedge iCLK)
begin
case(r_CMD)
CMD_READ : CMD_Period <= PER_READ-1;
CMD_WRITE : CMD_Period <= PER_WRITE-1;
CMD_BLK_ERA : CMD_Period <= PER_BLK_ERA-1;
CMD_SEC_ERA : CMD_Period <= PER_SEC_ERA-1;
CMD_CHP_ERA : CMD_Period <= PER_CHP_ERA-1;
CMD_ENTRY_ID: CMD_Period <= PER_ENTRY_ID-1;
CMD_RESET : CMD_Period <= PER_RESET-1;
endcase
end
//////////////// Command State LUT ////////////////
always
begin
case(ST)
IDEL: begin
FL_ADDR <= 22'h000000; mDATA <= 8'h00;
end
P1: begin
FL_ADDR <= 22'h000AAA; mDATA <= 8'hAA;
end
P2: begin
FL_ADDR <= 22'h000555; mDATA <= 8'h55;
end
P3: begin
FL_ADDR <= 22'h000AAA; mDATA <= 8'h80;
end
P4: begin
end
P5: begin
end
P3_PRG: begin
FL_ADDR <= 22'h000AAA; mDATA <= 8'hA0;
end
P3_DEV: begin
FL_ADDR <= 22'h000AAA; mDATA <= 8'h90;
end
P4_PRG: begin
FL_ADDR <= r_ADDR; mDATA <= r_DATA;
end
P6_BLK_ERA:
begin
FL_ADDR <= r_ADDR<<12; mDATA <= 8'h30;
end
P6_SEC_ERA:
begin
FL_ADDR <= r_ADDR<<16; mDATA <= 8'h50;
end
P6_CHP_ERA:
begin
FL_ADDR <= 22'h000AAA; mDATA <= 8'h10;
end
READ: begin
FL_ADDR <= r_ADDR; mDATA <= 8'h00;
end
RESET: begin
end
endcase
end
endmodule
Wow!
So, the chip on your board is Spansion not SST?
And it also works when contain does big change again & again?
Looks interesting~!
yes, the flash is Spansion.
i have tried to write a song into the flash using the example code, and the WM8731 can sing the song, so i say the board works well.
Very strange&#65281;
It still works after re-programming?
Chip Erase time should around 1 minute for most of Flash 32Mb~64Mb in my experience.
If this is true, you found a very fast way to make a Flash programmer.
--- Quote Start ---
--- Quote End ---
i tried a lot of times.sometimes,the kit works well after re-programming, when i long the chip erase time to 45s, everytime is nice. so i think the example code is wrong.
as your mentioned, the code is for SST flash.
