Please help to check is it all below MPN have same tray size, tray Matrix Row-Column & same orientation ?
Is it all below parts are 324-Pin FineLine Ball-Grid Array (FBGA) with tray size 19mmx19mm (Daewon 12U-1919-GXX), tray matrix row-column ( 6x14)?
5M1270ZF324C5N |
5M1270ZF324I5N |
5M2210ZF324I5N |
5M1270ZF324C4N |
5M2210ZF324C5N |
5M2210ZF324C4N |
Hi Supeng Ong,
Thank your for reaching out to Intel FPGA Community.
Regarding your question, yes, I can confirm that all of the listed MPN have the same tray size which is 19mmx19mm, 324-Pin FineLine Ball-Grid Array (FBGA) and can have total of 84 unit per tray as refer in the Application Notes (AN-071). You can obtained the Application Notes here Intel® FPGA Package and Thermal Information
Aqid Ayman
Hi Supeng Ong,
Aqid Ayman
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get support from Intel experts. Otherwise, the community users will continue to help you on this thread.
Thank you.
