5542 Discussions
uC/Probe working on NEEK board
May i know anyone have try to implement the uc/probe on the nios ii embedded evaluation kit?
After a research about this, i had found the development kit called BeMicro-SDK which have a similar architecture with the NEEK and also it using the uC/Probe to display the output to PC.
So i follow one of the tutorial from BeMicro-SDK to make it on my NEEK board, i had follow all the concept provided with different application but when i reach to the module 6.4 to run the uc/probe. It did not display any result on the data screen.
Can anyone tell me how to make it work on the NEEK board, or i had miss out something on the process so it wouldn't display on the data screen.
Besides, i had tried to trace the problem and i figure out the ISR handler for the "UCPROBE_JTAG" not trigger. i really no idea how to solve it.
Wish someone can guide and help me. THANKS.
here the links:
http://www.arrownac.com/solutions/bemicro-sdk/
http://www.arrownac.com/solutions/bemicro-sdk/files/bemicro-sdk-materials.zip
http://wiki.analog.com/resources/fpga/altera/all_hdl#bemicro_sdk
