ubuntu boot fail on DE1-SOC
I got wrong message during boot ubuntu. and then stop on starting kernel...
U-Boot SPL 2013.01.01 (Nov 04 2013 - 19:51:38)
BOARD : Altera SOCFPGA Cyclone V Board
SDRAM: Initializing MMR registers
SDRAM: Calibrating PHY
SEQ.C: Preparing to start memory calibration
SEQ.C: CALIBRATION PASSED
ALTERA DWMMC: 0
U-Boot 2013.01.01 (Dec 29 2013 - 17:29:53)
CPU : Altera SOCFPGA Platform
DRAM: 1 GiB
MMC: ALTERA DWMMC: 0
In: serial
Out: serial
Err: serial
Net: mii0
Hit any key to stop autoboot: 5 4 3 2 1 0
reading uImage
3948904 bytes read in 1328 ms (2.8 MiB/s)
reading socfpga.dtb
17170 bytes read in 12 ms (1.4 MiB/s)
reading soc_system.rbf
7007184 bytes read in 2354 ms (2.8 MiB/s)
altera_load: Failed with error code -4
fpgaintf
ffd08028: 00000000 ....
fpga2sdram
ffc25080: 00000000 ....
axibridge
ffd0501c: 00000000 ....# # Booting kernel from Legacy Image at 00007fc0 ...
Image Name: Linux-3.12.0-00307-g507abb4-dirt
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 3948840 Bytes = 3.8 MiB
Load Address: 00008000
Entry Point: 00008000# # Flattened Device Tree blob at 00000100
Booting using the fdt blob at 0x00000100
XIP Kernel Image ... OK
OK
Loading Device Tree to 03ff8000, end 03fff311 ... OK
Starting kernel ...
Did you resolve this issue. I see the same issue on this board. Based on some other threads i have tried to use dd command to copy the image myself, but the /dev/fpga0 partition is not loaded.
Gate_keeper
Check the MSEL switch at the botton of the board.
If you are booting the LXDE linux flavor, you will need to ground all MSEM pins.
If you need the /dev/fpga0 to be present, you can actually boot LXDE with the other uImage, the one used in Yocto's flavor.
This workaround is presented by ep1015 in this thread: http://www.alteraforum.com/forum/showthread.php?t=47258
That is what I need right now as I'm trying to run OpenCL on LXDE, but I could not manage xserver to work on it yet :(
regards
