5930 Discussions
using RAM memory on de1 board (Cyclone II)
hellol,
I have a question about reading and writing from the RAM memorys that are on-board of the DE1.
from what i have read: there are 3 types of memory installed:
8Myte SDRAM, 512 Kbytes Sram , 4Mbytes flash.
i want to use the ram memory (dont know who should i choose)
and found this code templtae in quartus:
--- Quote Start ---
-- Quartus II VHDL Template
-- Simple Dual-Port RAM with different read/write addresses but
-- single read/write clock
library ieee;
use ieee.std_logic_1164.all;
entity simple_dual_port_ram_single_clock is
generic
DATA_WIDTH : natural := 8;
ADDR_WIDTH : natural := 6
port
clk : in std_logic;
raddr : in natural range 0 to 2**ADDR_WIDTH - 1;
waddr : in natural range 0 to 2**ADDR_WIDTH - 1;
data : in std_logic_vector((DATA_WIDTH-1) downto 0);
we : in std_logic := '1';
q : out std_logic_vector((DATA_WIDTH -1) downto 0)
end simple_dual_port_ram_single_clock;
architecture rtl of simple_dual_port_ram_single_clock is
-- Build a 2-D array type for the RAM
subtype word_t is std_logic_vector((DATA_WIDTH-1) downto 0);
type memory_t is array(2**ADDR_WIDTH-1 downto 0) of word_t;
-- Declare the RAM signal.
signal ram : memory_t;
begin
process(clk)
begin
if(rising_edge(clk)) then
if(we = '1') then
ram(waddr) <= data;
end if;
-- On a read during a write to the same address, the read will
-- return the OLD data at the address
q <= ram(raddr);
end if;
end process;
end rtl;
--- Quote End ---
now, i undestand that it does an 2-D array but there i things that i dont figure:
1. if the adress witdh is 8 and word size is 6 that makes a: (2^8 *6) = 512bit memory right?
2. how can i connect this entity for it to use the wanted memory?
3.what memory should i choose:SRAM or SDRAM (i need to work on dual mode)
thank alot
Pini Sberro
Your design is using FPGA internal RAM, obviously the best idea with a rather small memory unit. It's the only memory, that can be operated dual-port, as intended. Alls external memories are single port.
From the external memories, only SRAM is available for simple interface. But you have to connect all memory signals to your design.
thats bad news for me.
I was asked in class to use the external memory. But i was told that it support dual mode too, are u certain its not?
And Is there a simple way to write to the external memories?
Thanks alot
