After compiled the example source vector_add, I read the project file top.qpf into the Quartus Prime Pro 17.1 and synthesized the system. But Quartus can not generate kernel_system_mandelbrot_kernel_system.ip.
You are not supposed to import and synthesize OpenCL designs manually inside of Quartus. Use the standard flow provided by the OpenCL compiler itself.
Hi, all,
Thanks for reply. I know the opencl compilation steps, and the system
can be compiled and run at the FPGA board successfully. My question is
that when I read into the compiled project file (top.qpf), which is
generated by the opencl compilation (aoc command), into the Quartus
Prime Pro, and synthesized it to take a look at the circuit
architecture, the errors I mentioned occurred.
Thanks a lot.
Tan
