version in the RPD file
FRava3
Is it possible to add some bytes of version information directly in the RPD file generated via "convert files" tool? I do not want to add the informations manually, I would like some sort of automation when converting the POF into RPD.
JohnT_Intel
There is no such features but you may add hex file into part of your file generation where the hex file will need to be manually modified to embed the version information.
