After updating 4x25G related .bin file into N3000 and rsu the bmc , when i checked the information with command of "sudo fpgainfo phy", port 0, port 1 and port 3 were all down and only port 2 was up. However, in the case of 8x10G, after updating binary file, all ports were up automatically without any other operations when checking the info.
Then my question is why there is only port 2 is up in 4x25G mode? And any solutions to make all ports up?
Thanks!
Which OPN are you using?
BD-NFV-N3000-1 :Production 10 GbE
OR
BD-NVV-N3000-2: Production 25 GbE
Did you program the BD-NFV-N3000-1 card with 4x25G image?
Maybe I was wrong on the understanding of 8x10G.
I found my BC is N3000-2 after checking my order,which means the BC is not supported for the mode of 8x10 G. And all ports were up in 8x10G may be only an illusion or a good fortunate.
I did not test it before. So im not sure of the full impact of putting a 10G image into 25G card.
But still thank you for your reply as it reminds me some detail but important information about the board card and some problems may be avoided for this.
For more complete information about compiler optimizations, see our Optimization Notice.
