cancel
Showing results for
Search instead for
Did you mean:
40Gbps Ethernet MACPHY IP reference design
Last Major Update
February 19, 2013
Downloadable Reference Design File
40G_SV_REL12.1.zip
Reference Documents
Altera 40- and 100-Gbps Ethernet MAC and PHY MegaCore Function User Guide (PDF)
Altera 100G Development Kit, Stratix V GX Edition (PDF)
[1]
Introduction
This reference design demonstrates the operation of Altera® 40-Gbps Ethernet MAC and PHY IP solution on a Stratix V device (5SGXEA7N2F45C2ES). It is configured to demonstrate on a 100G Development Kit, Stratix V GX Edition Board using Altera development tool Quartus II release 12.1. This design provides a flexible test and demonstration platform which effectively control, test, and monitor 40Gbps Ethernet packets using internal serial PMA loopback and external optical loopback through CFP module.
This hardware demonstration reference design offers the following features:
• Stand-alone and easy-to-use reference design example with flexibility to dynamically select traffic profile.
• Uses a standard 256-bit Avalon-ST interface to connect to the Ethernet Packet Generator and Monitor.
• Provides packet statistics for Generator and Monitor at the end of each test to further confirm the test result.
• Provides throughput measurement for the packet data received by the monitor.
• Window sterm terminal based flexible, reusable, and extendable user control interface allows users to dynamically configure and monitor any configuration registers provided by this demo design.
System Overview and Functional Description
The hardware platform consists of three sub-systems:
• The 40G Ethernet MAC and PHY IP
• Packet Client with random packet Generator and Monitor
•sterm terminal for configuration and control of the system
This system can be represented by the following diagram:
e/e1/40Ge_Example.jpg
The Altera 40G Ethernet MAC and PHY IP core is implemented in compliance with the IEEE 803.3ba 2010 Higher Speed Ethernet Standard. This module handles the frame encapsulation and flow of data between a client logic and Ethernet network via a 40GbE Ethernet PCS and PMA (PHY). In the TX direction, the MAC accepts client frames, inserts inter-packet gap (IPG), preamble, start of frame delimiter (SFD), header, padding, and checksum before passing them to the PHY. The PHY encodes the MAC frame as required for reliable transmission over the media to the remote end. Similarly, in the RX direction, the MAC accepts frames from the PHY, performs checks, updates statistics counters, strips out the CRC, preamble, and SFD, and passes the rest of the frame to the client.
Packet Client with Random Packet Generator and Monitor
The Packet Client includes a Packet Generator and a Packet Monitor. These modules have 256-bit Avalon-ST interface for the data-path and connect to the 40G Ethernet MAC. There is also a 32-bit Avalon-MM configuration and status interface associated with both the generator and monitor. The generator can generate random packets. Monitor parses all packets received from MAC and checks the integrity of the packets.
sterm.exe Terminal System Controller
This reference design provides a windows terminal program sterm.exe which can run on a PC (windows based operating system). User must provide byte addresses in order to access registers on chip using this interface.
40Gbps Ethernet MAC and PHY IP Overview
As mentioned in previous sections, the 40G Ethernet sub-system consists of 40G MAC and PHY sub-modules. The MAC client side data path interface has two options: Avalon ST interface and Custom ST interface. This reference design uses an Avalon-ST interface which includes interface adapter. This adapter then provides a standard Avalon-ST interface for the MAC client. The MAC connects to the PHY core over XLGMII interface. The 40G Ethernet IP core can be demonstrated as the following simplified diagram: 3/3e/40Ge_MACandPHY.jpg
Additional Functional Details of 40GE Ethernet IP Core
The additional details of the IP core can be found in the User guide. The IP core evaluation package and the user guide can be downloaded from Altera website:http://www.altera.com/products/ip/iup/ethernet/m-alt-40-100gb-ethernet.html
Quick Start Guide
The reference design setup essentially consists of three parts:
  • 100G Stratix V GX development board hardware setup
  • 100G Development Kit – Stratix V GX Edition v11.1.2 setup
  • Quartus II 12.1 and SignalTap II Logic Analyzer setup
  • Windows based sterm Terminal System Controller setup
The relevant setups for each of these components are provided in detail as shown below:
100G Stratix V GX Development Board Hardware Setup
The 100G Stratix V GX development board requires minimum hardware setup. A one time setting is required to ensure the following:
1. The CFP is connected to an optical loopback cable.
2. The DIP switches (FPGA USER and MAX USER) SW4 and SW5 shown on the right side of the board (in the picture below) are pushed towards the edges of the PCB (tied low). These switches were used only during the development to debug the correct settings of CFP controls and are not required to be changed by the user.
3. The MSEL Pin settings switch SW2 should read MSEL [4:0] = 00100
4. The SW3 should read 7:0 = 1101111
5. The Fan bypass and MAX_JTAG_EN jumpers J9 and J62 shunt positions should be Not Installed.
Before turning on power switch at the upper left corner of the development board, two cables need to be connected into development kit:
1. Power supply cable with adaptor to provide 19V DC voltage.
2. USB blaster cable connected between PC and development board.
3. An optical loopback cable is installed tightly into the CFP module.
b/bc/40Ge_100GDB.jpg
100G Development Kit - Stratix V GX Edition v11.1.2 Setup
Install the 100G development kit – Stratix V GX Edition v11.1.2 from 100G Development Kit, Stratix V GX Edition Board which is required for Clock Control for the 100G Stratix V GX development board.
1. Open the Clock Control application and read the U53 Si5338 registers. U53 Si5338 oscillator supplies the pins AF6/AF7 which is connected to reference input clock.
4/46/40Ge_cc1.jpg
As seen the Clk2 register reads 644.5313, which is to be changed to 322.2656 for this particular reference design.
2. Input the 322.2656 in Clk2 register field, keeping the others same and click on Set New Frequency.
5/5d/40Ge_cc2.jpg
Quartus II 12.1 and SignalTap II Logic Analyzer Setup
1. Open the alt_e40_avalon_top_sv.qar as project in Quartus II 12.1 subscription edition, it will ask to restore the project. Check for proper names and directories. As soon as the unarchiving is complete the project alt_e40_avalon_top_sv.qpf will be loaded. The designed is compiled and already has alt_e40_avalon_top_sv.sof to be downloaded on development board.
2. Open the SignalTap II Logic Analyzer by double clicking on stp1.stp from files tab in project navigator. The TX and RX signals to be monitored are already added to the instance.
3. Program the board from SignalTap II Logic Analyzer. The MAX_JTAG_EN jumpers J62 shunt position should be Installed. On successful operation the Instance Manager will show “Ready to acquire”.
Windows Terminal Setup
Navigate to utility/terminal64 directory and open the sterm.exe
The following should appear.
5/51/40Ge_check.jpg
1. Execute the following commands to verify clocks
a. reg_read 0x0002 //to read CLK_TXS giving 257,xxx KHz
b. reg_read 0x0003 //to read CLK_RXS giving 257,xxx KHz
c. reg_read 0x0004 //to read CLK_TXC giving 315,xxx KHz
d. reg_read 0x0005 //to read CLK_TXC giving 315,xxx KHz
b/b3/40Ge_clk_chk.jpg
2. Execute the following commands to perform External Optical Loopback.
a. reg_read 0x1010        //to read the enable register triggering the traffic generator
b. reg_write 0x1010 00000001 //to set the enable register triggering the traffic generator to generate packets.
c. reg_read 0x1010        //to verify the above write operation
0/04/40Ge_ext_opt_loopback.jpg
OR
2. Execute the following commands to perform Internal Serial Loopback.
d. reg_read 0x0061        //to read the register enabling the internal serial loopback of TX and RX
e. reg_write 0x0061 ffffffff    //to set the register enabling the internal serial loopback of TX and RX
f. reg_read 0x0061         //to verify the above write operation*
*(getting back 0000000f indicates proper write operation and set of proper register)
3/37/40Ge_int_ser_loopback_on.jpg
SignalTap II Logic Analyzer instance waveform verification
Click on Autorun Analysis to acquire waveform on the data tab. You can verify the status of various signals from the MegaCore function user guide.
6/64/40Ge_SignalTapII.jpg
Hardware demo design Package
Reproducing the hardware demo design can be done at various levels of the development flow. A quick regeneration of SOF file needs compilation and regeneration of the files provided with the download. The downloaded archive file consists of the following sub-directories under top level directory: 40G_SV_REL12.1.
1.alt_e40_avalon_top_sv/example_design – it contains RTL files for Ethernet and other logic blocks
2. example_testbenches - directory that contains compile and simulation run scripts
3. Utility/terminal64 – windows based sterm Terminal System Controller
Running Simulation
Unzip and populate the 40G Ethernet demo design. The demo design provides test benches in the example_testbenches/SV_alt_e40_avalon_tb directory and scripts in all the four EDA (vsim, vcs, ncsim and aldec) directories necessary to compile and run a simulation. Please follow the following steps to perform the simulation.
1. copy the example_testbenches to alt_e40_avalon_top_sv/gen_40_example
2. Open gen_40.v with MegaWizard Plug-In Manager and then click "Finish" button to generate simulation libraries.
3. Navigate to alt_e40_avalon_top_sv/gen_40_example/example_testbenches/SV_alt_e40_avalon_tb/vsim in command prompt
4. On the command window execute vcs –c –do run_vsim.do and watch for messages until the process is complete.
5. At the end of the simulation the tool will provide a summary of how many packets received with Error.
Similarly execute other EDA scripts for simulations.
Compile the design
Please follow the following steps to recompile the design.
2. Start Quartus 12.1 software. Please do not create any project.
3. Open the alt_e40_avalon_top_sv.qpf file provided with the design.
4. Upon a successful load, start comprehensive compile and wait for the process to finish.
5. At the end of the compile, SOF file is generated.
Known Issue
Please note that the system flexible testing platform. We have done a limited number of testing with an intention to demonstrate the inter-op of the two sub-systems. Additional test cases can be created by creating various kind of difference setting to the sub-system.
Disclaimer
© [2012] Altera Corporation. The material in this wiki page or document is provided AS-IS and is not supported by Altera Corporation. Use the material in this document at your own risk; it might be, for example, objectionable, misleading or inaccurate.
Version history
Last update:
‎06-26-2019 03:07 PM
Updated by:
Contributors
