cancel
Showing results for
Search instead for
Did you mean:
834 Discussions
Altera Triple-Speed Ethernet IP Core Timing Constraints
Introduction
Altera provides constraint files to ensure that the Triple-Speed Ethernet MegaCore function meets design timing requirements in Altera devices. You might need to add timing constraints which are external to the MegaCore function.
How to modify the generated constraint file?
Follow the steps below to modify the generated constraint file:
Open and modify generated constraint files
  • Edit <variation_name>_constraints.tcl and <variation_name>_constraints.sdc according to your customized design. For example, if you change the clock names at the top-level design, edit the customer modifiable constraints in the <variation_name>_constraints.sdc file to change the clock names shown below:
# Name the clocks that will be coming into the tse core named changed from top level
set TX_CLK "tx_clk"
set RX_CLK "rx_clk"
set CLK "clk"
set FF_TX_CLK "ff_tx_clk"
set FF_RX_CLK "ff_rx_clk"
set TBI_TX_CLK "tbi_tx_clk"
set TBI_RX_CLK "tbi_rx_clk"
set REF_CLK "ref_clk"
The generated SDC file includes the clock names for all core configurations. However, you only need to constrain the clocks that are relevant to your core configuration. For the clock names that require timing constraint in the SDC, refer to Table 2-2 to Table 2-6.
  • Table 2-2 lists the clock signals that require timing constraint for 10/100/1000 Mbps Ethernet MAC.
  • Table 2-3 lists the clock signals that require timing constraint for 10/100/1000 Mbps Ethernet MAC with 1000BASE-X/SGMII PCS.
  • Table 2-4 lists the clock signals that require timing constraint for 1000BASE-X/SGMII PCS.
  • Table 2-5 lists the clock signals that require timing constraint for 10/100Mb Small MAC and 1000Mb Small MAC.
Table 2-2 Timing Constraint Requirement for 10/100/1000 Mbps Ethernet MAC Clock Signals
Clocks
Configurations(1)
With internal FIFO
Without internal FIFO
TX_CLKYesYes
RX_CLKYesYes
CLKYesYes
FF_TX_CLKYes-
FF_RX_CLKYes-
TBI_TX_CLK--
TBI_RX_CLK--
REF_CLK --
Notes to Table 2-2:
(1) Yes indicates that the clock requires timing constraint at the top-level design.
— indicates that the clock is not applicable for the given configuration.
Table 2-3 Timing Constraint Requirement for 10/100/1000 Mbps Ethernet MAC with 1000BASE-X/SGMII PCS Clock Signals
Clocks
Configurations(1)
With internal FIFO
With PMA block
Without PMA block
With PMA block
Without PMA block
TX_CLK----
RX_CLK----
CLKYesYesYesYes
FF_TX_CLKYesYes--
FF_RX_CLKYesYes--
TBI_TX_CLK-Yes-Yes
TBI_RX_CLK-Yes-Yes
REF_CLKYes-Yes-
Notes to Table 2-3:
Table 2-4 Timing Constraint Requirement for 1000BASE-X/SGMII PCS Clock Signals
Clocks
Configurations (1)
With PMA block
Without PMA block
TX_CLK--
RX_CLK--
CLKYesYes
FF_TX_CLK--
FF_RX_CLK--
TBI_TX_CLK-Yes
TBI_TX_CLK-Yes
REF_CLKYes-
Notes to Table 2-4:
Table 2-5 Timing Constraint Requirement for 10/100 Mbps Small MAC and 1000 Mbps Small MAC Clock Signals
Clocks
Configurations (1)
With internal FIFO
TX_CLKYes
RX_CLKYes
CLKYes
FF_TX_CLKYes
FF_RX_CLKYes
TBI_TX_CLK-
TBI_RX_CLK-
REF_CLK-
Notes to Table 2-5:
Constrain design clock frequency
  • Constrain the clock frequency according to your customized design. If your design requires a different operating frequency, edit the SDC file to make changes to the frequency parameters shown below:
# Frequency of network-side interface clocks or reference clocks
set TSE_CLOCK_FREQUENCY "125 MHz"
# Frequency of FIFO data interface clocks
set FIFO_CLOCK_FREQUENCY "100 MHz"
# Frequency of control and status interface clock
set DEFAULT_SYSTEM_CLOCK_SPEED "66 MHz"
For the list of clock names that will be affected by these frequency parameters, refer to Table 2-6.
Clocks
Frequency Parameter (1)
TSE_CLOCK_FREQUENCY
TX_CLK
Yes
RX_CLK
Yes
CLK
Yes
FF_TX_CLK
Yes
FF_RX_CLK
Yes
TBI_TX_CLK
Yes
TBI_RX_CLK
Yes
REF_CLK
Yes
Notes to Table 2-6:
(1) Yes indicates that the clock is applicable to the frequency parameter.
— indicates that the clock is not applicable for the frequency parameter.
To get more understanding on TSE timing design constraint and its flow, please refer to this design example: www.alterawiki.com/wiki/Altera_Triple-Speed_Ethernet_Timing_Contraints_Design_Example
For more information about timing analyzers, refer to the Timing Analysis section in volume 3 of the Quartus II Handbook and the Quartus II Help.
Version history
Last update:
‎06-21-2019 06:51 PM
Updated by:
Contributors
