Contents[hide] |
Initial Release - December 2014 - Arria 10 Hard Memory Controller DDR3 933MHz Quarter Rate x72 Dual rank UDIMM, Quartus II v14.1, Arria 10 External Memory Interface.
This design is meant as a demo style lab. It very briefly covers the steps required to design a 72-bit wide, 933-MHz DDR3 SDRAM hard memory interface working with a Arria 10 FPGA using a 72-bit wide DDR3 SDRAM interface accessing one MT18JSF1G72AZ-1G9 DDR3 SDRAM UDIMM module. The purpose of the lab is for the reader to get a basic feel for what steps are involved in getting an external memory working with an Altera FPGA and the Arria 10 External Memory Interface IP. The lab will not cover any of the steps in detail but simply show an overview of the design process. Volume 2: Design Guidelines of the External Memory Interface Handbook should be used for a more thorough walkthrough.
To demonstrate the DDR3 SDRAM functionality, this lab will use the example design option provided in Arria 10 External Memory Interface IP. The synthesis example design will be later modified to add other components to demonstrate the flexibility of the example design to suite user needs.
Note that, all available Arria 10 devices including the target device for this lab are currently marked as either Advanced or Initial in Quartus II v14.1, thus no programming file will be generated. However, to ensure the steps are correct, similar design as in this lab has been created and verified through internal hardware testing. Thus, should the design need to be tested in different board (once the programming file support is available), the steps should remain the same but the design may require some modification (e.g. IP parameters and pin location assignment) and regeneration in latest Quartus release so that that it will match with the target board and to ensure it continue to work correctly.
The table below lists the specifications for this design:
Attribute | Specification |
Quartus version | 14.1 |
FPGA | 10AX115S3F45I2LG (Advanced) |
Board / Kit | Internal Board |
Memory device | DDR3 SDRAM (Micron MT18JSF1G72AZ-1G9) |
Memory speed | 933-MHz |
Memory topology | x72-bit, 1 DDR3 SDRAM Dual rank UDIMM |
IP used | Arria 10 External Memory Interface |
Simulator used | ModelSim SE 10.3c |
The lab uses Quartus II v14.1 and has ModelSim set up for simulation. The lab assumes the reader is a competent user of these tools and many of their features.
Three files have been pre-designed for this lab to save time:
1. A pin location assignments TCL script ( 10ax115s3f45i2lg_pin_assignment.tcl )
2. A custom Component Definition File of Example Design In-System Source and Probe ( ed_iss_hw.tcl )
3. A custom RTL wrapper for Example Design In-System Source and Probe ( ed_iss.v )
Files for this lab are located in this lab_files.tar.gz file.
Create a new folder for the project and place the files according to the instruction.
An archive for the final project is located in this a10egdesign.tar.gz file for reference.
1. In the Quartus II software, create a Quartus II project using the New Project Wizard available from the File menu. For this lab, use following information to setup the project accordingly:
2. Launch the IP Catalog from the Tools menu
3. Double click Arria 10 External Memory Interfaces IP from the Memory Interfaces and Controllers folder in the Library list. IP Parameter Editor will be launch.
4. In New IP Variation window, specify the Entity name and click OK. For this lab, use following information to setup the IP variation accordingly.
5. In Presets window, select the preset matching or closest to the target memory device. For this lab, use ' DDR3-1866M CL13 UDIMM 1R x72 2GB (9 x256Mb x8) ' preset. Click Apply.
Note : Based on MT18JSF1G72AZ-1G9 datasheet, we know that protocol is DDR3, the speed grade is -1G9, the Memory CAS latency (CL) is 13 and the data rate 1866 MT/s. Thus the closest preset is 'DDR3-1866M CL13 UDIMM 1R x72 2GB (9 x256Mb x8)'
6. Specify the parameters on all tabs. The value should be based on the target memory device, FPGA device and board being used. For this lab, use following information to configure the remaining IP parameter that should be different than the default value or the preset.
Important Note : Review any warning messages displayed in the Messages Window and correct any errors before making further changes
Important Note : Instead of leaving it to default, ensure the parameters in Board Timing tab are configured correctly based on the actual target board as the value are vary from board to board. Use HyperLynx or similar simulator to obtain values of the actual target board.
Important Note : Take note on the info messages regarding which address/command pin placement scheme that need to follow based on the final IP setting. This info will be needed during pin assignment in the later stage.
Note : For Board and Package Skews, use Board Skew Parameter Tool available in Altera web to compute the value
Note : For detailed explanation of the parameters, refer to Parameterizing Memory Controllers with Arria 10 External Memory Interface IP chapter of the External Memory Interface Handbook.
7. Click Example Design button at the top-right corner of the Parameter window, confirm the default path for the example design, and click OK.
8. Once the generation completed, click Close.
9. Click Finish. The configuration is saved as dut.qsys which located inside < your project folder > directory.
10. Since this lab will only use the example design files, click No when prompted to generate your IP.
11. In Integration with the Quartus II Software window, click Close.
12. Click Yes when prompted to add the Quartus II IP File to the project.
13. In terminal, change directory to < your project folder >/emif_0_example_design folder and run following commands in sequence:
i. $ quartus_sh -t make_qii_design.tcl
ii. $ quartus_sh -t make_sim_design.tc
Note : Review the readme.txt file generated under < your project folder >/emif_0_example_desig/qii/altera_emif_arch_nf_141/synth folder. The file contains high-level overview, recommendation and requirements of the IP based on the selected configuration.
1. Place the ed_iss.v and ed_iss_hw.tcl inside the < your project folder >/emif_0_example_design folder.
2. Launch the Qsys from the Tools menu.
3. In Open dialog box, navigate into < your project folder >/emif_0_example_design folder, select the ed_synth.qsys file and click Open.
4. Once the process of opening the system has been completed, click Close. An example design system containing the Arria 10 External memory Interface IP, EMIF example Avalon Traffic Generator and other miscellaneous blocks will appear in the System Contents window.
5. Since in this example we going to use the our own hw.tcl component, we need to add the path to the hw.tcl file so Qsys know where to find it. To do that click Tools > Option. Then, click the Add button and browse to the project folder where you place the ed_iss_hw.tcl before you click Finish.
6. In IP Catalog window, double click Example Design In-System Sources and Probes in the Library list to add the component into the system.
7. In Example Design In-System Sources and Probes GUI, click Finish. You can see in System Contents window a new component called ed_iss_0 is added.
8. Un-export the following signal by double click their corresponding export signal name in the Export column and delete the name.
9. Make the following connection from ed_iss_0 interfaces
10. Click Finish to save the system into the existing ed_syth.qsys file.
11. Click No when prompted with Generate Now?.
i. $ rm -rf qii
ii. $ quartus_sh -t make_qii_design.tcl
Note : Alternative of using this custom component to add ISS is to add following Quartus II assignment in ed_synth.qpf file. This will enable the existing ISS that has been instantiated inside the IP RTL.
1. In the Quartus II software, open the generated example design Quartus II project ( ed_synth.qpf) using the Open Project available from the File menu. The Quartus II project file should be under < your project folder >/emif_0_example_desig/qii folder.
2. Assign the location for all top level pins. Pin locations for external memory systems are not automatically created as it depend on the individual board layout and device package being used. For this lab, do the following steps:
i. Place the 10ax115s3f45i2lg_pin_assignment.tcl in < your project folder >/emif_0_example_desig/qii.
ii. Launch the Tcl Scripts from Tools menu.
iii. In the TCL Scripts window, select the 10ax115s3f45i2lg_pin_assignment.tcl script under the Project folder in the Libraries and click Run to run the script.
iv. Click OK when a window appeared indicating the script has been executed and click Close to close the TCL Scripts window .
v. Verify in Pin Planner or Assignment Editor available under the Assignments menu to ensure the pin locations has been assigned correctly
Note : Board designer should comply with the following pin-out guideline when designing the board. To ensure the correctness, cross-check the pin location assignment with the respective document too.
3. Run full compilation by clicking the Start Compilation under the Processing menu. The compilation may take around 10 minutes to complete depending on compilation PC.
4. Once the compilation complete, ensure that there are no timing violation. There are 2 areas that should be check as below:
5. Review all the Critical Warnings and Warnings and determines if it is acceptable or need to be address.
Important Note : All available Arria 10 devices including the target device for this lab are currently marked as either Advanced or Initial, thus no programming file will be generated. The following steps are just to demonstrate the various method to program and verify the design in the hardware which can be followed once the programming file support is available. For this lab to work, steps described under the Adding Components Into Existing Example Design topic is compulsory to be followed.
1. In the Quartus II software, launch In-System Sources and Probes Editor from Tools menu.
2. In Jtag Chain Configuration window under In-System Sources and Probes Editor GUI, configure the Hardware and Device based on the targeted board. For File, browse for the ed_synth.sof file and click Open.
3. Click Program Device button to configure the FPGA.
4. Once the configuration is successful (Ready to acquire), select all source and probe instances and click the Continuously Read Probe Data button next to Instance Manager label. The In-System Sources and Probes Editor Pane will shows the acquired data from each instances.
5. In In-System Sources and Probes Editor Pane, click the GRST or RSTN instance value under the Data column to change it from 0 to 1. This will de-assert the global_reset_n signal in the hardware.
6. Observe the data for CALS or CALP and TGP instances change from 0 to 1 which indicate the calibration is success and pass the example driver tests.
1. In terminal, change directory to < your project folder >/emif_0_example_design/sim/mentor folder and run following commands
2. ModelSim SE will be launched and the compilation and simulation will be run. The simulation may take around 60 minutes to complete depending on compilation PC.
3. Once the simulation stopped, observe the pass_all signal in waveform window to ensure it goes high and a " --- SIMULATION PASSED --- " string displayed in the ModelSim terminal to ensure the RTL simulation has passed.
