Success! Subscription added.
Success! Subscription removed.
Sorry, you must verify to complete this action. Please click the verification link in your email. You may re-send via your profile.
This basic design example demonstrates the implementation of Arria V LVDS in DPA mode. With DPA mode enabled, the DPA block will help to choose the best possible sampling clock from the eight sampling clock sent from fractional PLL (fPLL). This would improve the receiver channel's jitter tolerance and ability to sample the incoming data correctly. In this design, In-System Source and Probe (ISSP) is used to control the resets, RX bit slip and DPA hold signals. Plug in the HSMC loopback board onto the Arria V starter kit to loopback the data from TX to RX. Then compile the design and program the device. Open up the stp1.stp SignalTap file and link to the Arria V device. You should observe the tx_locked, rx_locked and rx_dpa_locked are asserted. The rx_out might have incorrect word boundary after power up. Launch the In-System Source and Probe instance at Project Navigator -> Files -> Spf2.spf. You may apply RX bit slip by controlling the source[1] in the ISSP to achieve the right word boundary.
Arria V LVDS in DPA mode design example QII v13.1 (QAR)
The table below lists the specifications for this design:
Attribute | Specification |
Device | ArriaV GX |
Quartus version | QuartusII v13.1 |
Development Kits | Altera Arria V Starter Kit |
Data rate | 600Mbps |
Data pattern | Fixed |
Number of channels | 1 |
IP used | ALTLVDS_TX, ALTLVDS_RX |
This basic design example demonstrates the implementation of Arria V LVDS with DPA in soft-CDR mode. By having the soft-CDR mode in place, only the serial data is sent from the transmitter (TX) to the receiver (RX). The RX will be able to recover the sampling clock from the serial data received. This will help to save the board resource on the clock routing.
In this design, In-System Source and Probe (ISSP) is used to control the resets, RX bit slip and DPA hold signals. Plug in the HSMC loopback board onto the Arria V starter kit to loopback the data from TX to RX. Then compile the design and program the device. By default, you should observe that the RX DPA hold signal is asserted. Since the TX and RX are driven by different on-board oscillators, there is a ppm difference between the TX and RX. With the DPA tracking held, you should observe the RX parallel data output drifts. Launch the In-System Source and Probe instance at Project Navigator -> Files -> Spf2.spf. Write a value of '1' to the source[2] to release the DPA hold and allow the DPA to track the incoming serial data. You should now observe the RX parallel data output remain stable. You may then apply RX bit slip by controlling the source[1] in the ISSP to achieve the right word boundary.
Arria V LVDS with DPA in soft-CDR mode design example QII v13.1 (QAR)
Data rate | 500Mbps |
Community support is provided during standard business hours (Monday to Friday 7AM - 5PM PST). Other contact methods are available here.
Intel does not verify all solutions, including but not limited to any file transfers that may appear in this community. Accordingly, Intel disclaims all express and implied warranties, including without limitation, the implied warranties of merchantability, fitness for a particular purpose, and non-infringement, as well as any warranty arising from course of performance, course of dealing, or usage in trade.
