cancel
Showing results for
Search instead for
Did you mean:
Avalon Fast Downloader
This component allows you to download at up to 300KBytes/sec. This is 5 to 6 times faster than the standard nios downloads. This example contains the hardware component, and drivers for system console as well as an example java application. See AvalonFastDownloader.doc for full details. All hardware and driver sources are also availible in Fast_downloader.zip
Compatible with Quaruts 9.1
WARNING: For this component to work the target memory must support byte writes at a minimum of 2Mhz. There is no way to backpressure this downloader. I have never seen a problem with this restriction except in cases where other masters are running and using all the bandwidth.
CategoriesEmbedded ProcessingEmbedded Hardware and Hardware Tools
Version history
Last update:
‎06-21-2019 09:18 PM
Updated by:
Contributors
