Success! Subscription added.
Success! Subscription removed.
Sorry, you must verify to complete this action. Please click the verification link in your email. You may re-send via your profile.
Read the file header for usage documentation.
The attached script allows users to back-annotate location assignments for a design. There are wildcards that allow the user to wildcard the node names that get back-annotated and/or the type of location that gets back-annotated. The debug mode(which is on by default) will just dump the location assignments to the command prompt, so the user can dump it into a text file.
I do NOT recommend back-annotating a design. Node names, especially combinatorial node names, change with each synthesis run, so if a user back-annotates their whole design, makes a small change, and then resynthesizes, most of the combinatorial node location assignments will no longer work and the user will get a worse fit. This issue is solved by using Design Partitions for locking down logic, which is the recommended flow.
Where I do find this script to be the most useful is finding the exact name/syntax for locking down a particular type of node. The most common things I've used it for is locking down PLLs or clock trees(clkctrl). I generally run it in debug mode, match the name or type of logic I want to lock down, pipe the results into a file( >> ba_results.txt) and then cut and paste the ones I want into my .qsf
Community support is provided during standard business hours (Monday to Friday 7AM - 5PM PST). Other contact methods are available here.
Intel does not verify all solutions, including but not limited to any file transfers that may appear in this community. Accordingly, Intel disclaims all express and implied warranties, including without limitation, the implied warranties of merchantability, fitness for a particular purpose, and non-infringement, as well as any warranty arising from course of performance, course of dealing, or usage in trade.
