Success! Subscription added.
Success! Subscription removed.
Sorry, you must verify to complete this action. Please click the verification link in your email. You may re-send via your profile.
April 26, 2012
This example demonstrates a number of custom system console dashboards that were created to interact with an example system loaded into the BeMicro SDK development board to stimulate and listen to a number of peripherals. Onchip RAM, LEDs, push buttons, SPI Thermometer and various serial interfaces are represented in the example system. Nearly all of the available system console widget types are represented in the demonstration.
This example consists of an archive of the source material to build the entire hardware project and system console scripts required to execute the demo on the BeMicro SDK board. There is also a PDF file that illustrates the various dashboards present in the demonstration.
Download the archive for this example and place it in a directory on your system that does not include spaces in the path name. The entire path name of this directory must not contain spaces, so on Windows systems you should avoid putting this in the "My Documents" folder, or on your "Desktop" since these locations are subdirectories of the "Documents and Settings" path, and that would mean that these locations inherit the spaces in that part of the path name.
In order to extract the archives after downloading them, it is recommended that you run the "tar xzf <filename>" command from a bash shell. For linux users you should have ready access to a bash shell. For windows users, you may need to install the Altera development tools to gain access to a bash shell. On Windows it is recommended that you install the complete Altera ACDS development tools which includes the Nios II EDS development tools. Once these tool chains are properly installed on your workstation, you can launch a bash shell by running:
"Start -> Programs -> Altera -> Nios II EDS X.x -> Nios II X.x Command Shell"
Once you are in the bash shell, you can "cd" into the directory containing the archives that you've downloaded, and running the following command to extract them:
tar xzf <archive_filename>
Note that if you use some other archiving software to extract these archives, like WinZip, you may lose the execution privileges on some of the shell scripts within the archives that are used to perform various activities associated with building and using the example. If this happens, you can restore execute privileges from within a bash shell with the command "chmod +x <filename>". It is recommended that you avoid this situation by using "tar" to extract the archives from within a bash shell and avoid using any Windows oriented archive utilities with these archives.
Once the archive is extracted, you should locate a readme.txt file in the top level of the archive directory. Read the contents of that file for additional information about building and running the example.
This example was created and tested with the Altera ACDS 11.1sp2 development tools. Once built, the example runs on the BeMicro SDK evaluation board.
20120426 - Initial posting.
© 2012 Altera Corporation.
The material in this wiki page or document is provided AS-IS and is not
supported by Altera Corporation. Use the material in this document at your own
risk; it might be, for example, objectionable, misleading or inaccurate.
Community support is provided Monday to Friday. Other contact methods are available here.
Intel does not verify all solutions, including but not limited to any file transfers that may appear in this community. Accordingly, Intel disclaims all express and implied warranties, including without limitation, the implied warranties of merchantability, fitness for a particular purpose, and non-infringement, as well as any warranty arising from course of performance, course of dealing, or usage in trade.
