Success! Subscription added.
Success! Subscription removed.
Sorry, you must verify to complete this action. Please click the verification link in your email. You may re-send via your profile.
0. You need a 32-bit Linux system to build the toolchain.
you need gcc3 and makeinfo to build. On OpenSUSE:
yum install compat-gcc-34 texinfo tetex*
On Ubuntu:
sudo apt-get install texinfo texlive
On Ubuntu, you will need to find gcc-3.4, gcc-3.4-base, and cpp-3.4 packages from Ubuntu 9.04.
Some versions of Ubuntu use mawk instead of gawk. You will nee to install gawk.
1. get the source: ftp://sopc.et.ntust.edu.tw/pub/gnutools/nios2gcc4/wrs-linux-4.1-176-nios2-wrs-linux-gnu.src.tar.bz2
2. get the patches: ftp://sopc.et.ntust.edu.tw/pub/gnutools/nios2gcc4/
0001-binutils-fix-makeinfo-version-check-in-configure.patch
0001-gcc-fix-makeinfo-version-check-in-configure.patch
0001-gdb-fix-makeinfo-version-check-in-configure.patch
0001-kbuild-fix-C-libary-confusion-in-unifdef.c-due-to-g.patch
build.sh
REAME (this file)
3. untar the source
tar jxf wrs-linux-4.1-176-nios2-wrs-linux-gnu.src.tar.bz2
4. in the wrs-linux-4.1-176-nios2-wrs-linux-gnu dir, there are source tarballs. extract them to build dir, /opt/nios2gcc4/src.
cd wrs-linux-4.1-176-nios2-wrs-linux-gnu
tar jxf binutils-4.1-176.tar.bz2 -C /opt/nios2gcc4/src
tar jxf expat-4.1-176.tar.bz2 -C /opt/nios2gcc4/src
tar jxf gcc-4.1-176.tar.bz2 -C /opt/nios2gcc4/src
tar jxf gdb-4.1-176.tar.bz2 -C /opt/nios2gcc4/src
tar jxf glibc-4.1-176.tar.bz2 -C /opt/nios2gcc4/src
tar jxf glibc_localedef-4.1-176.tar.bz2 -C /opt/nios2gcc4/src
tar jxf glibc_ports-4.1-176.tar.bz2 -C /opt/nios2gcc4/src
tar jxf linux-4.1-176.tar.bz2 -C /opt/nios2gcc4/src
5. apply the patches
cd /opt/nios2gcc4/src/binutils-2.17.50
patch -p1 < 0001-binutils-fix-makeinfo-version-check-in-configure.patch
cd /opt/nios2gcc4/src/gcc-4.1
patch -p1 < 0001-gcc-fix-makeinfo-version-check-in-configure.patch
cd /opt/nios2gcc4/src/gdb-wrs
patch -p1 < 0001-gdb-fix-makeinfo-version-check-in-configure.patch
cd /opt/nios2gcc4/src/linux-2.6.21-wrs-nios2
patch -p1 < 0001-kbuild-fix-C-libary-confusion-in-unifdef.c-due-to-g.patch
6. run the build script, you can change the build dir, /opt/nios2gcc4 and install dir /opt/nios2.
bash build.sh
7. you will need mkimage of u-boot or install it from debian/ubuntu package uboot-mkinage.
Community support is provided Monday to Friday. Other contact methods are available here.
Intel does not verify all solutions, including but not limited to any file transfers that may appear in this community. Accordingly, Intel disclaims all express and implied warranties, including without limitation, the implied warranties of merchantability, fitness for a particular purpose, and non-infringement, as well as any warranty arising from course of performance, course of dealing, or usage in trade.
