Success! Subscription added.
Success! Subscription removed.
Sorry, you must verify to complete this action. Please click the verification link in your email. You may re-send via your profile.
This is about using busybox alone , not under buildroot or uClinux-dist.
You can download the latest snapshot or stable release from busybox.net.
Busybox, .config for cross compile
# Build Options
CONFIG_STATIC=y
# CONFIG_BUILD_LIBBUSYBOX is not set
# CONFIG_FEATURE_FULL_LIBBUSYBOX is not set
# CONFIG_FEATURE_SHARED_BUSYBOX is not set
CONFIG_LFS=y
USING_CROSS_COMPILER=y
CROSS_COMPILER_PREFIX="nios2-linux-uclibc-"
EXTRA_CFLAGS_OPTIONS="-Dfork=vfork -Ddaemon=clone"
# CONFIG_BUILD_AT_ONCE is not set
# Installation Options
# CONFIG_INSTALL_NO_USR is not set
CONFIG_INSTALL_APPLET_SYMLINKS=y
# CONFIG_INSTALL_APPLET_HARDLINKS is not set
# CONFIG_INSTALL_APPLET_DONT is not set
PREFIX="/home/hippo/rootfs"
I used this flags before, (but not now)
EXTRA_CFLAGS_OPTIONS="-D__uClinux__ -Dfork=vfork"
busybox_unstripped: .depend $(LIBBUSYBOX_SONAME) $(BUSYBOX_SRC) $(libraries-y)
$(do_link) $(PROG_CFLAGS) $(PROG_LDFLAGS) $(CFLAGS_COMBINE)
-Wl,-elf2flt="-s 16000" -Wl,-v -Wl,-d
-o $@ -Wl,--start-group
$(APPLETS_DEFINE) $(APPLET_SRC)
$(BUSYBOX_DEFINE) $(BUSYBOX_SRC) $(libraries-y)
$(LDBUSYBOX) $(LIBRARIES)
-Wl,--end-group
busybox: busybox_unstripped
$(Q)cp busybox_unstripped busybox
# $(do_strip)
There is an important issue about busybox. It takes more memory on MMU-less arch.
So I moved away from busybox a little. I use stand alone init, sash, and servers from uClinux-dist. I built others utils into busybox. See UClinuxDist.
Tout le monde a les moyens et doit de se procurer un coffre-fort et il faut prendre un coffre-fort de type coffre fort ignifuge homologué S120P ou une armoire forte ignifuge agréée 2 heures feu
Community support is provided Monday to Friday. Other contact methods are available here.
Intel does not verify all solutions, including but not limited to any file transfers that may appear in this community. Accordingly, Intel disclaims all express and implied warranties, including without limitation, the implied warranties of merchantability, fitness for a particular purpose, and non-infringement, as well as any warranty arising from course of performance, course of dealing, or usage in trade.
