CPRI v6 Errata
cancel
Showing results for
Search instead for
Did you mean:
CPRI v6 Errata
CPRI v6 Errata
Back to Changelog
Contents
 [hide
Errata List
The following table records the known issues for CPRI v6 IP, full description of each issue is described later in this page. If you need a patch(fix) of this issue in your current build, please contact engineering for support.
Errata noIssued DateVersion/BuildDescriptionFix in
37601911 May, 201615.1.313Ethernet Tx PCS with MII interface may experience packet drop16.0.249
37602111 May, 201615.1.313Ethernet Rx PCS with MII interface may experience state machine deadlock16.0.249
37606112 May, 201615.1.313Ethernet Tx PCS with GMII interface may experience packet drop16.1.275
37628512 May, 201615.1.313Ethernet Tx and Rx PCS with GMII interface could not reset thoroughly16.1.275
37710217 May, 201615.1.313Ethernet Tx with MII interface at 3072Mbps may corrupt some packet(s)16.0.249
38007730 May, 201615.1.313Stratix V line bit rate auto-negotiation to 9.8304Gbps (or lower rate) may not work16.0.249
4107451 Mar, 201716.0.249Incorrect LOS LOF RAI value during reset16.1.275
4369601 Mar, 201716.0.249LCV counter has incorrect bit width16.1.275
4409461 Mar, 201716.1.275Vendor Specific Slot may be overridden when Pointer-P = 016.1.285
4409491 Mar, 201716.1.275vs_tx_rdy has no assertion or absent on certain basic frame16.1.285
44707222 Mar, 201716.1.285SDC error for single-trip delay calibration17.0.260
4753227 Aug, 201716.1.285LCV counter causes deadlock in frame re-synchronization17.0.260
4756187 Aug, 201716.1.285Register (0x5C) XCVR_BITSLIP - tx_bitslip_en is not connected to transmitter17.0.260
4646757 Aug, 201716.1.285Ethernet MII (<3Gbps) has low throughput17.0.260
4471777 Aug, 201716.1.285Register (0x30/34/38) CTRL_INDEX/TX_CTRL/RX_CTRL hang during read operation17.0.260
4438277 Aug, 201716.1.285Double assertion on aux_tx_rfp_sync may cause link fail17.0.260
4791507 Aug, 201716.1.285HDLC serial interface bandwidth issue at 240kbit/s (001)17.0.260
4784907 Aug, 201716.1.285Register (0xC) BIT_RATE_CONFIG not in Read-only mode17.0.260
4804837 Aug, 201716.1.285aux_tx_err port give false assertion when IF_LATENCY > 0 mode is used17.0.260
4778137 Aug, 201716.1.285(Simulation) Link issue in line bit rate option 7A/8 when rate auto-negotiation is turned on17.0.260
4727857 Aug, 201716.1.285(Enhancement) Improve soft FIFO initial delay consistency after re-synchronization17.0.260
4356357 Aug, 201716.1.285(Enhancement) Additional LOS/LOF bits added in register (0x2C) LFSAR17.0.260
4756097 Aug, 201716.1.285Disable Tx local clock division factor (2,4,8) for <5Gbps in Arria 1017.0.260
4756227 Aug, 201716.1.285Disable Rx recovered clock option for Arria 1017.0.260
48419816 Aug, 201717.0.260"VCCR_GXB and VCCT_GXB supply voltage for the Transceiver" Option is redundant in CPRI GUITBD
48789825 Aug, 201717.0.260Line bit rate auto-negotiation should be disabled for 1.2288Gbps in Arria 10/Stratix 10TBD
5074511 Nov, 201717.0.260Testbench generation failure in Windows PlatformTBD
Fixed in 16.0.249
376019 Ethernet Tx PCS with MII interface may experience packet drop
  • Description : When sending Jumbo packet(s), Tx Ethernet PCS may drop the packet when Pointer-P is set to minimum (63)
  • Affected configuration : Line bit rate 9.8304Gbps and above
  • Workaround : No workaround
376021 Ethernet Rx PCS with MII interface may experience state machine deadlock
  • Description : When Rx Ethernet PCS hit FIFO full condition, the Rx state machine may be stuck and stop processing packet(s)
  • Affected configuration : All configuration with Ethernet PCS MII interface
  • Workaround : Perform a reset on the Ethernet Rx PCS through mii_rxreset port
377102 Ethernet Tx with MII interface at 3072Mbps may corrupt some packet(s)
  • Description : Packet(s) may be corrupted when Ethernet Tx PCS is sending multiple packet(s) at 3072Mbps
  • Affected configuration : 3072Mbps
  • Workaround : Reset Ethernet Tx PCS with mii_txreset
380077 Stratix V line bit rate auto-negotiation to 9.8304Gbps (or lower rate) may not work
  • Description : Link will be down after switching from 10.1376Gbps to lower rates (8b10b variant)
  • Affected configuration : Stratix V 10.1376 Gbps
  • Workaround : No workaround (quick RTL fix available for 15.1)
Fixed in 16.1.275
376061 Ethernet Tx PCS with GMII interface may experience packet drop
  • Description : Tx Ethernet PCS may drop the packet when FIFO almost full or full condition is seen on eth_gmii_tx_fifo port
  • Affected configuration : All configurations
376285 Ethernet Tx and Rx PCS with GMII interface could not reset thoroughly
  • Description : Packet(s) may be corrupted when Ethernet PCS is reset with gmii_txreset/gmii_rxreset only without global reset
  • Workaround : Reset both gmii_txreset/gmii_rxreset and global reset/reset_tx/reset_rx
410745 Incorrect LOS LOF RAI value during reset
  • Description : Local LOS/LOF/RAI bits are not set at 1 during reset stage, receiving partner node may not get correct link information
  • Affected : All configuration
436960 LCV counter has incorrect bit width
  • Description : Line Code Violation (LCV) counter saturated at 4bit and not able to count 16 or more LCV in a hyperframe
Fixed in 16.1.285
440946 Vendor Specific Slot may be overridden when Pointer-P = 0
  • Description : When Pointer-P is set to 0, some slot of Vendor Specific (VS) will be override with Ethernet default value 8'hFF
  • Workaround : No workaround (quick RTL fix available for 16.1.275)
440949 vs_tx_rdy has no assertion or absent on certain basic frame
  • Description : vs_tx_rdy will not be asserted when Pointer-P is set to 0, and absent in some basic frames (32-47, 96-111, 160-175, 223-239) when Pointer-P value is set to 20-63
  • Affected : Configuration with Vendor Specific (VS) direct interface enabled
Fixed in 17.0.260
447072 SDC script error for configuration with Single-trip delay calibration enabled
  • Description : Typo error in generated SDC file which prevent full compilation, halt at fitter stage
  • Affected : Slave configuration with Single-trip delay calibration feature enabled
  • Workaround : Edit SDC on line with keyword of "set_Registers" and change to "set_registers"
475322 LCV counter causes deadlock in frame re-synchronization
  • Description : During CPRI startup, when excessive 8b10b violation is detected, LCV counter not able to reset due to no incoming HFP
  • Workaround : (hardware) Perform multiple resets when link not able to achieve link synchronization
475618 Register (0x5C) XCVR_BITSLIP - tx_bitslip_en is not connected to transmitter
  • Description : tx_bitslip_en malfunction as Tx bitslip function is disabled due to port not connected
  • Workaround : Edit generated wrapper - Connect altera_cpri xcvr_tx_std_bitslipboundaryselect to transceiver tx_std_bitslipboundselect port manually
464675 Ethernet MII (<3Gbps) has low throughput
  • Description : MII may experience extremely low throughput (<1Mbps) and packet loss conditions
  • Affected : Ethernet MII configuration with line bit rate 3Gbps and below
  • Workaround : No workaround (quick fix file for pre-17.0 available)
447177 Register (0x30/34/38) CTRL_INDEX/TX_CTRL/RX_CTRL hang during read operation
  • Description : Management interface hang (cpu_waitrequest never deassert) when these registers are accessed without "Enable all Control word access via Management interface"
  • Affected : All configuration without "Enable all Control word access via Management interface"
443827 Double assertion on aux_tx_rfp_sync may cause link fail
  • Description : Asserting aux_tx_rfp_sync pulses that is too close (< IF_LATENCY+1) to each other will disrupt the framing process and core may not be able to recover
  • Affected : All configuration with Auxiliary interface turned on
  • Workaround : No workaround (quick fix for pre-17.0 available)
479150 HDLC serial interface bandwidth issue at 240kbit/s (001)
  • Description : Additional hdlc_tx_rdy pulses maybe observed on the HDLC serial interface as bandwidth control is missing in the RTL, HDLC slot(s) are not transmitted/received correctly
  • Affected : HDLC configuration with Z.66.0 set to 3'b001
478490 Register (0xC) BIT_RATE_CONFIG not in Read-only mode
  • Description : Reading register BIT_RATE_CONFIG may return non-static bit rate value
  • Affected : Configuration with rate auto-negotiation turned off
480483 aux_tx_err port give false assertion when IF_LATENCY > 0 mode is used
  • Description : aux_tx_err may asserts incorrectly when IQ slot is written from AUX interface,
  • Affected : All configuration with Auxiliary interface enabled and interface latency is set to >0
477813 Link issue in line bit rate option 7A/8 when rate auto-negotiation is turned on
  • Description : Link may not be able to achieve Hyperframe synchronization in option 7A and 8 due to malfunction in simulation model
  • Affected : Rate auto-negotiation is turned on for line bit rate option 7A and 8, simulation only
472785 Improve soft FIFO initial delay consistency after re-synchronization
  • Description : Upon different reset, additional delay of 5 clock cycles may be observed in soft FIFO
  • Workaround : Reset core
475609 Removal of Tx local clock division factor value (2,4,8) for lower line bit rate (<5Gbps) Arria 10
  • Description : These values are not valid and are removed from Arria 10 support to align with NativePHY transceiver
  • Affected : Arria 10 with line bit rate lower than 5Gbps
475622 Removal of Rx recovered clock source option for Arria 10
  • Description : Recovered clock source will be from PCS directly, no other option available
  • Affected : Arria 10 slave configuration
Fixed in future releases
484198 "VCCR_GXB and VCCT_GXB supply voltage for the Transceiver" Option is redundant in CPRI GUI when non Stratix 10 devices are selected
  • Description: The option is visible when non Stratix 10 devices are selected but will have no effect
  • Affected: All configurations which uses a non Stratix 10 device
  • Workaround: No workaround - please ignore this parameter option
487898 Line bit rate auto-negotiation should be disabled for 1.2288Gbps in Arria 10
  • Description : The line bit rate auto-negotiation option in GUI for 1.2288Gbps configuration in Arria 10 is not valid and should be disabled
  • Affected : All Arria 10 configuration
  • Workaround : No workaround (please do not enable line bit rate auto-negotiation for Arria 10 1.2288Gbps configuration)
507451 Testbench generation failure in Windows platform
  • Description : Generation of the IP core simulation files will fail, generation of HDL synthesis files are not affected
  • Affected : All configuration/device when Windows installer is used
  • Workaround : Locate the altera_cpri_demo_tb_sim.tcl model file in <quartus installation>/ip/altera_cloud/cpri_ii/altera_cpri_ii_ed/ip_sim/ and change the line of "set dir $::env(PWD)" to "set dir env(%cd%)"
Version history
Last update:
‎06-24-2019 11:46 PM
Updated by:
Contributors
