cancel
Showing results for
Search instead for
Did you mean:
CVO IP video mode detection and switching feature
Last Major Update
New Release for Stratix V - December 12th 2016 - Quartus II v16.1 Installed
Design Overview
This design demonstrates:
a) Video mode detection and switching feature of CVO IP
b) Run time configure the TPG and Interlace IP to generate difference type of video format
Here is the top level diagram of the design:
 4/4f/Top_level_CVO_design.png
The Video Source Block contains Test Pattern Generator (TPG), Interlacer IP, and CVO IP. This video source block is used to generate difference type of video formats, which include PAL (SD-SDI), 720p60 (HD-SDI) and 1080p60 (3G-SDI).
The CVO IP is configuring to three difference video models by using the “video_format.tcl”. The CVO IP will detect the incoming video format and switch the video model accordingly.
Model 1: 720p60
Model 2: 1080p60
Model 3: PAL
The CVO’s vid_clk is connected to SDI’s “tx_clkout” when transmit 3G-SDI, for other video formats, the CVO’s vid_clk is connected to “tx_dataout_valid”.
Please take note that the “vid_clk” is not glitch-free in this design, and above connection of "vid_clk" is not recommended for the production.
The “vid_std” signal is an output signal of the CVO, it output the value (e.g SD-SDI = 0, HD-SDI = 1 and 3G-SDI =3) that you configure at Model Standard Register of CVO (address 12), and this signal can be connected to SDI IP (tx_std signal).
Hardware Setup:
 0/0b/Hardware_setup_DSP.png
This design was compiled for Quartus Prime v15.1 for Stratix V DSP Development Kit.
a) SDI_TX (J17) can connect to SDI signal Analyzer
b) Or the SDI_TX(J17) can connect to SDI_RX(J16) to perform serial loopback test
Running the Design:
1) Download the design:
v15.1 -> File:SV CVO SDI 15 1 wiki.zip
v16.1 -> File:Sample top v16.1.qar
2) Open stp1_sk.stp and download the sof file to FPGA
3) Open config.tcl file, and modify the “SDI_Mode” parameter for difference video format (1=SD (PAL), 2= HD (720p60), 3=3G (1080p60)).
4) Open system console and change the directory to “.../sample_top_SV_DSP_triple_Rate_15_1/sc_tcl”
5) Type source config.tcl in TCL Console
6) Connect the SDI_TX (J17) to SDI signal Analyzer and investigate the signals
7) For serial loopback test, you can verify the following signals from signal tap:
a. “rx_format” (PAL -> 0x1, 720p60 -> 0x7, 1080p60 -> 0xc)
b. “rx_frame_locked” is asserted
Version history
Last update:
‎06-24-2019 11:49 PM
Updated by:
Contributors
