cancel
Showing results for
Search instead for
Did you mean:
Cyclone III Active Serial Remote Update with Nios II
A step by step description for using Nios II to control dual boot configuration on Cyclone III with SPI flash.
Application note environment
For this AN, I’ve used a board from Devboards, the DBM2 module.
The AN demonstrates how to setup a dual boot configuration from a third party serial flash – The Numonyx M25PX32 - 64 sectors (64 Kbytes each).
The reboot request is managed by a NiosII application which is located in internal RAM.
This flow has been tested with the version 10.0 of QuartusII and NiosIIEds.
NiosII System Creation w/ SOPC_BUILDER
APP #1 9/94/App-1.JPG
 Take care to set the clock of the Remote_Update_Controller to 25Mhz.
APP #2 3/32/App-2.JPG
QuartusII Compilation
Set the “Configuration Mode to REMOTE” and select
“Generates compressed bitstreams”
JIC file creation
That is the trickiest part.
The main recommendation is:
Do not let the tool setting the “Start Address” for you .
In fact, if you set the “Start Address” to “AUTO”, it will set addresses which are not aligned with what the Remote Update controller is capable to drive. The two LSB should be zero.
In my example, I took the Start Address of 0x60000
6/62/Start_address.JPG
NiosII Application w/ SBT
Do create a “NiosII Application and BST” for each NiosII system.
Example code is:
#include "sys/alt_stdio.h"
#include "io.h"
#include "system.h"
  1. define ConfigStartAdd <PUT THE RIGHT START @>
  2. int main()
  3. int BootAddress ;
  4. int LastestBootAddress;
  5. int StatusRegs;
  6. alt_putstr("Hello from Application #1!\n");
/* Wait until CONF button pushed */
while(IORD(CONF_BASE, 0x0)) {};
BootAddress = IORD(RUC_BASE, 0x4);
LastestBootAddress = IORD(RUC_BASE, 0xC);
StatusRegs = IORD(RUC_BASE, 0xFF);*/
/* Let's go to App #2 */
IOWR( RUC_BASE, 0x3, 0x0); /*Disable Watchdog */
IOWR( RUC_BASE, 0x4, ConfigStartAdd/4);
IOWR( RUC_BASE, 0x20, 0x1 );
while (1);
return 0;
EPCS configuration
Using the QuartusII programmer, add the JIC file as the configuration file, select Program/Configure.
0/08/Qii_prog_image.JPG
Test
The default configuration will be APP1 at @=0x0
The second boot will be APP2 at @=0x60000
Using the nios2-terminal after each CONF assertion shows the following output.
4/49/Nios2_terminal.JPG
© 2010 Altera Corporation. The material in this wiki page or document is provided AS-IS and is not
supported by Altera Corporation. Use the material in this document at your own risk; it might be, for example, objectionable,
misleading or inaccurate.
Version history
Last update:
‎06-25-2019 04:20 PM
Updated by:
Contributors
