Success! Subscription added.
Success! Subscription removed.
Sorry, you must verify to complete this action. Please click the verification link in your email. You may re-send via your profile.
This page presents a demo that shows a bare-metal application running from EPCQ Flash, on a Cyclone V Soc Development Kit, without using SDRAM. Some more details about the demo: EPCQ Flash (1MB window) is used for program and read only data HPS OCRAM (64KB) is used for regular data storage
Interrupts are demonstrated
The following are required for this demo: For running the demo: Cyclone V Development Kit, rev E preferable SoC EDS 16.1 (for Quartus Flash Programmer) Serial terminal running on PC (TeraTerm for example) For compiling the Preloader: SoC EDS 16.1 For compiling and debugging the bare-metal application: SoC EDS 16.1, including ARM DS-5
The following are included with this demo:
The sample application archive soc_dev_kit_boot_epcq.tar.gz contains the following:
soc_dev_kit_xip_epcq
ip/
soc_system.qsys - updated qsys file to use the correct pinmuxing for UART on our devkit
output_files/
soc_system.sof - updated fpga configuration file, resulted after recompiling with the updated qsys
hps_isw_handoff/
soc_system_epcq_hps_0 - updated handoff file resulted after recompiling with the updated qsys
software
Altera-SoCFPGA-HardwareLib-EPCQ-XIP-CV-GNU - bare-metal application, sources, precompiled binaries and debug launchers
spl_bsp_epcq - updated preloader, sources and precompiled binaries
preloader_epcq.patch - preloader patch
create_preloader.sh - script to automate creating the preloader
output_file.cof - convert programming file configuration, uses relative paths
output_file.jic - epcq flash image
program_epcq.cdf - quartus programmer configuration, uses relative paths
prepare_jic.sh - script to prepare jic file. Uses the cof file to find the components
flash_jic.sh - script to flash the jic to EPCQ
In order to run the demo, the following steps need to be performed:
1. Start an Embedded Command Shell
2. Configure the Board to boot from FPGA by setting the BSEL jumpers accordingly:
BSEL0 | BSEL1 | BSEL2 | Description |
Left | Right | Right | FPGA |
3. Set the MSEL jumpers accordingly:
MSEL0 | MSEL1 | MSEL2 | MSEL3 | MSEL4 | MSEL5 | |
Up | Down | Up | Up | Down | Down |
4. USB blaster connected to PC
5. Connect the board to the PC using the USB serial connection, and start a serial terminal on the PC, using 115,200-8-N-1.
6. Run the script to flash the provided EPCQ image to the EPCQ, power cycle the board and see the Preloader and bare-metal application running on the console:
cd soc_dev_kit_xip_epcq
./flash_jic.sh
* takes ~4 minutes to flash EPCQ
Info: *******************************************************************
Info: Running Quartus Prime Programmer
Info: Version 16.0.0 Build 211 04/27/2016 SJ Standard Edition
Info: Copyright (C) 1991-2016 Altera Corporation. All rights reserved.
Info: Your use of Altera Corporation's design tools, logic functions
Info: and other software and tools, and its AMPP partner logic
Info: functions, and any output files from any of the foregoing
Info: (including device programming or simulation files), and any
Info: associated documentation or information are expressly subject
Info: to the terms and conditions of the Altera Program License
Info: Subscription Agreement, the Altera Quartus Prime License Agreement,
Info: the Altera MegaCore Function License Agreement, or other
Info: applicable license agreement, including, without limitation,
Info: that your use is for the sole purpose of programming logic
Info: devices manufactured by Altera and sold by Altera or its
Info: authorized distributors. Please refer to the applicable
Info: agreement for further details.
Info: Processing started: Mon Apr 3 12:46:55 2017
Info: Command: quartus_pgm program_epcq.cdf
Info (213045): Using programming cable "USB-BlasterII [1-2.2]"
Info (213011): Using programming file ./output_file.jic with checksum 0x2E6FC8AF for device 5CSXFC6D6@2
Info (209060): Started Programmer operation at Mon Apr 3 12:47:01 2017
Inconsistency detected by ld.so: dl-close.c: 762: _dl_close: Assertion `map->l_init_called' failed!
Info (209016): Configuring device index 2
Info (209017): Device 2 contains JTAG ID code 0x02D020DD
Info (209007): Configuration succeeded -- 1 device(s) configured
Info (209018): Device 2 silicon ID is 0x19
Info (209044): Erasing ASP configuration device(s)
Info (209023): Programming device(s)
Info (209021): Performing CRC verification on device(s)
Info (209011): Successfully performed operation(s)
Info (209061): Ended Programmer operation at Mon Apr 3 12:51:18 2017
Info: Quartus Prime Programmer was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 475 megabytes
Info: Processing ended: Mon Apr 3 12:51:18 2017
Info: Elapsed time: 00:04:23
Info: Total CPU time (on all processors): 00:00:26
* power cycle the board, you will see this on the console:
U-Boot SPL 2013.01.01 (Apr 02 2017 - 09:22:37)
BOARD : Altera SOCFPGA Cyclone V Board
CLOCK: EOSC1 clock 25000 KHz
CLOCK: EOSC2 clock 25000 KHz
CLOCK: F2S_SDR_REF clock 0 KHz
CLOCK: F2S_PER_REF clock 0 KHz
CLOCK: MPU clock 800 MHz
CLOCK: DDR clock 400 MHz
CLOCK: UART clock 100000 KHz
CLOCK: MMC clock 488 KHz
CLOCK: QSPI clock 400000 KHz
RESET: WARM
Reading header from EPCQ flash
Hello EPCQ World!
Running 256KB test_function_1() without caches enabled : 19424723 ticks.
Caches enabled
Preload 256KB test_function_1() in L2 cache : 19427699 ticks.
Running 256KB test_function_1() from preloaded cache : 18111 ticks.
Running 512KB test_function_2() : 38785599 ticks.
Running 512KB test_function_2() : 24785337 ticks.
Running 256KB test_function_1() from preloaded cache : 18105 ticks.
Global Timer Interrupt: 1 of 1000
Global Timer Interrupt: 2 of 1000
Global Timer Interrupt: 3 of 1000
Global Timer Interrupt: 4 of 1000
This section describes how to re-compile the demo if any changes are necessary.
To re-create the Preloader based on the handoff information, that may have changed
./create_preloader.sh
* creates the following:
soc_dev_kit_xip_epcq/software/spl_bsp_epcq/preloader.hex <- Preloader HEX image, used for flashing
These are the steps done by the above script, that can also be done manually: 1. Delete the existing preloader directory.
cd soc_dev_kit_xip_epcq/software/
rm -rf spl_bsp_epcq
2. Use bsp-editor to generate a Preloader
bsp-editor &
3. In bsp-editor, perform the following changes to the default configuration parameters
* Select the Preloader Settings Directory to be hps_isw_handoff/soc_system_epcq_hps_0/
* Uncheck Use default locations
* Edit the BSP target directory to be soc_dev_kit_xip_epcq/software/spl_bsp_epcq
* Click OK
* Uncheck BOOT_FROM_SDMMC
* Check BOOT_FROM_QSPI
* Check EXE_ON_FPGA
* Check SKIP_SDRAM
* Uncheck WATCHDOG_ENABLE
* Click Generate
4. Change current folder to the Generated Preloader
cd soc_dev_kit.updated/software/spl_bsp_epcq
6. Compile the Preloader using 'make' – this will bring in all source code
make
7. Clean the Preloader using the following command
make clean
8. Patch the Preloader source using the following command:
cd uboot-socfpga
patch -p1 < ../../../preloader_epcq.patch
The output will be something similar to the following:
patching file common/spl/spl.c
patching file drivers/mtd/spi/spi_spl_load.c
patching file include/configs/socfpga_common.h
cd ..
9. Recompile the Preloader using ‘make’:
make
10. Run the following command to convert the Preloader ELF file to HEX:
arm-altera-eabi-objcopy -O ihex --adjust-vma -0xc0000000 uboot-socfpga/spl/u-boot-spl preloader.hex
In this scenario, we are re-compiling the bare-metal application, to take into account any source code, or makefile changes:
2. Start ARM DS-5 AE by running the command ‘eclipse &’
3. Select a new workspace (or reuse an existing one)
4. Go to File -> Import -> General -> Existing Projects into Workspace and click ‘Next’
5. Choose ‘Select archive file’ option and click the associate ‘Browse’ button
6. Select the file ‘Altera-SoCFPGA-HardwareLib-EPCQ-XIP-CV-GNU’ and click ‘Open’
7. Click ‘Finish’ to import the project.
8. Go to Project->Build project. This will compile the project
To build from command line:
1. Start an Embedded Command Shell 2. Change the current folder to the Baremetal Source folder
cd soc_dev_kit_xip_epcq/software/Altera-SoCFPGA-HardwareLib-EPCQ-XIP-CV-GNU
3. Delete the existing binaries from previous build
make clean
4. Rebuild Baremetal binaries
make
soc_dev_kit_xip_epcq/epcq_demo.axf <- ELF image, used for debugging soc_dev_kit_xip_epcq/epcq_demo-mkimage.hex <- HEX image, used for flashing
This section presents how to debug the demo using ARM DS-5 Altera Edition.
Connecting to the running Bare-metal Application and Debugging It
1. Flash the EPCQ image to the EPCQ(by running script - flash_jic.sh)
2. Start Eclipse by running ‘eclipse&’ from the Embedded Command Shell.
3. Select any location on your hard drive as the ‘workspace’ location. Recommended to use soc_dev_kit_xip_epcq/software/workspace
4. In Eclipse, go to File > Import > General > Existing Projects into Workspace and click Next 5. In Import Projects window, click Browse to select the folder soc_dev_kit_xip_epcq/software/Altera-SoCFPGA-HardwareLib-XIP-EPCQ-CV-GNU, then click Finish
6. Go to Run -> Debug Configurations
7. In Debug Configuration, select Ds-5 Debugger > Debug-Running-Application
8. In Connection tab, click Browse under Bare Metal Debug to select the desired USB Blaster </br> 9. In the Connection Browser window, select the USB blaster to be the one you have connected and click Select
10.In the Debug Configurations window, click Debug
11.The DS-5 will connect to the board, stop the bare-metal application, and load the symbols from the ELF file
12.Usual debugging can now be done:
Debugging the Bare-metal Application from the Beginning
Here we run the bootrom, preloader and then we stop at the beginning of the bare-metal application, so that we can debug it from the beginning:
1. Repeat steps 1-5 as above
2. In Eclipse, go to Run > Debug Configurations
3. In Debug Configuration, select Ds-5 Debugger > Debug-Application-From-Beginning
4. In Connection tab, click Browse under Bare Metal Debug to select the desired USB Blaster
5. In the Connection Browser window, select the USB blaster to be the one you have connected and click Select
6. In the Debug Configurations window, click Debug
7. The DS-5 will connect to the board, reset it, then run BootROM and Preloader, load bare-metal symbols then run up to the bare-metal application main function.
8. Usual debugging can now be done:
This section presents a little bit more details about the demo architecture.
The placement of the images in EPCQ:
Element | File Name | EPCQ Address |
Main SOF | output_files/soc_system.sof | 0x00000000 |
Secondary SOF | output_files/soc_system.sof | 0x00800000 |
Preloader | software/spl_bsp_epcq/preloader.hex | 0x01000000 |
BM Application | software/Altera-SoCFPGA-HardwareLib-EPCQ-XIP-CV-GNU/epcq_demo-mkimage.hex | 0x01100000 |
The Preloader included in the 16.1 SoC EDS release does not natively supports the EPCQ XIP mode.
To support this :
1. Preloader .hex file should be linked to address 0xC0000000 (equivalent of offset 0x0 behind the HPS2FPGA bridge) . There is an internal address expander that shifts the address to (0xC1000000). Thus, Mapping to preloader residing at address 0x01000000 of EPCQ.
2. File uboot-socfpga/include/configs/socfpga_common.h
Enabled the EPCQ XIP and defined the EPCQ jump address to where Baremetal application resides ie address 0xC0100000. Thus, Mapping to Baremetal Application residing at address 0x01100000 of EPCQ.
3. File uboot-socfpga/drivers/mtd/spi/spi_spl_load.c
When Boot from QSPI is enabled , logic in function spl_spi_load_image() is executed. Added additional logic to support EPCQ XIP, this involves parsing the header at address 0xC0100000 and then executing the Baremetal application.
Element | H2F address | H2F address+ address expander | EPCQ Address |
Preloader | 0xC0000000 | 0xC1000000 | 0x01000000 |
BM Application | 0xC0100000 | 0xC1100000 | 0x01100000 |
The standard boot sequence is used, with the BootROM loading the Preloader, then the Preloader loading the bare-metal application:
The following table presents the linker sections that the bare-metal application uses. This setup was used for the following reasons:
Section | Start | Size | Description |
ram | 0xFFFF0000 | 64K-4K | Onchip RAM. Minus 4KB for the PLL workaround. |
epcq_rom_startup | 0xC0100040 | 16K – 64 | EPCQ: Startup code, needs to be at the beginning of the image. Minus 64 bytes for Mkimage header. |
epcq_rom_mmu_ttb1 | 0xC0104000 | 16K | EPCQ: L1 Translation Table |
epcq_rom_mmu_ttb2 | 0xC0108000 | 1K | EPCQ: L2 Translation Table |
epcq_rom | 0xC0108400 | 1M - 33K | EPCQ: Rest of it – code and constant data |
The following table presents the cache settings that were used.
Area | L1 Cacheable | L2 Cacheable |
1MB EPCQ Flash | Yes | Yes |
64KB OCRAM | Yes | No |
Rest of Memory | No | No |
Note that making OCRAM also L2 cacheable did not improve the speed of the system. That is because OCRAM has a similar speed with the L2 cache. However, making OCRAM L1 cacheable did make a significant improvement in execution speed.
The MMU tables are used to describe the cache settings for different memory areas. For this demo, the following Tables were used:
Notes:
The application preloads the desired piece of date to the L2 cache and locks it to improve the execution efficiency.
It uses the Lockdown by line feature of the L2 cache controller. When lockdown by line feature is enabled during a period of time, all newly allocated cache lines get marked as locked. The controller then considers them as locked and does not naturally evict them. Lockdown by line feature can be enabled by setting bit [0] of the Lockdown by Line Enable Register.
Two test functions were developed to test the cache lock feature:
The flow of the sample application is the following:
Community support is provided Monday to Friday. Other contact methods are available here.
Intel does not verify all solutions, including but not limited to any file transfers that may appear in this community. Accordingly, Intel disclaims all express and implied warranties, including without limitation, the implied warranties of merchantability, fitness for a particular purpose, and non-infringement, as well as any warranty arising from course of performance, course of dealing, or usage in trade.
