cancel
Showing results for
Search instead for
Did you mean:
DCFIFO with ALTECC Implementation Example Design
Contents
 [hide
Overview
This design example uses an DCFIFO to illustrate how the ECC feature can be implemented external to the FIFO. The ALTECC_ENCODER and ALTECC_DECODER IP cores are required as the ALTECC_ENCODER IP core encodes the data input before writing the data into the DCFIFO, while the ALTECC_DECODER IP core decodes the data output from the DCFIFO before transferring the data out to other parts of the logic.
Download
The example design and the details description of the design can be downloaded from the following links.
File:DCFIFO ECC ExampleDesign.zip
File:DCFIFO with ALTECC Implementation Example Design.pdf
System Requirements
Quartus II version 14.1
Disclaimer
This design example describes how ECC features can be implemented with the DCFIFO using ALTECC. However, the design example might not represent the optimized design or implementation.
Version history
Last update:
‎06-25-2019 04:35 PM
Updated by:
Contributors
