Success! Subscription added.
Success! Subscription removed.
Sorry, you must verify to complete this action. Please click the verification link in your email. You may re-send via your profile.
The memory interface registers in the NCO in non-constant mode can only support up to 32-bits currently.
For the memory interface, the supported format is either one or 2 registers per bus word. This does not apply in Constant mode, when interface is not used
This error arises when building the memory interface for NCOs. Check that the parameters relating to the memory map are consistent for the highlighted NCO.
DSPBA_features Media:DSPBA_features.doc is a mechanism to access some internal prameters of the tool by setting of worksapce variables DSPBA_Features.<feature name> = <value>. The values expected change according to the feature - some are integer values, others are boolean. If the wrong type is read, the above error is displayed. Make sure that the value you have specified is correct for the DSPBA_Feature used. Note that DSPBA_Features are subject to change, so are not recommended for general use.
This is an internal error; contact your Altera representative and submit a Service Request if you see this. The message occurs at the stage the tool casting between internal floating point formats in the optimization of floating point data-paths. It has attempted to cast between type internal floating point formats for which no casts function is supported. Since all legal casting operations should be supported, this should never occur.
Folding is a feature for automatically time-division multiplexing (TDMing) primitive subsystems. The feature is specified on the ModelPrim ChannelIn and ChannelOut blocks. For folded subsystems, the subsystem must contain precisely one ChannelIn block and one ChannelOut block. Ensure this is the case, if necessary aggregating all inputs through a single ChannelIn blocks and all outputs through a single ChannelOut block.
The parameters for folding - 'Number Of Used TDM Slots' and 'Sample Rate' - are specified both on the input ChannelIn and on the output ChannelOut. These parameterizations currently have to be identical (though in future we may support different input and outputs rates). Check that the folding parameters on the named ChannelIn are the same as those specified on the named ChannelOut.
In folded primitive subsystems, the tool uses the valid and channel signals internally to drive sequenced enables in the generated logic. For folding subsystems, these signals cannot therefore be connected to user logic on the data-path within the subsystem, but instead should be routed directly across to the ChannelOut block. The error messge is displayed if the valid of channel signal in the folded subsystem is routed to any other blocks. If you require these signals in your primitive subsystem design, a workaround is to bring additional copies of them in as data signals through the ChannelIn block.
When multiple TDM slots are specified in the folding parameters, the data input signal to the ChannelIn cannot be a vector. The restriction of scalar input to a folded ChannelIn arises as the tool re-uses the 1-dimension to add the folding dimension (and the tool currently does not support 'vectors of vectors'). Make sure all inputs to the specified folded ChannelIn block are scalars.
The Simulink enable block can be used to create a subsystem-wide enable signal when used at the same level as the boundary blocks (ChannelIn/Out, GPIn/Out). [Note: a) the Enable block which denotes and enabled subsystem cannot generally be used in subsystems embedded within a primitive subsystem (accept where the subsystem contains no synthesizable logic). i.e. generally the enable block can only appear at the 'top level' of the primitive subsystem b) using Enabled Subsystems may generate an enable signal with a large fan-out in HDL which can reduce achievable fmax c) sending the enable signal low immediately halts the Simulink simulation for the enabled subsystem - before any outputs are updated - and that includes stopping the generation of the stimulus capture files (STMs) from the primitive boundary blocks for HDL test-benching. The Simulink simulation will therefore not match when running the automated HDL test-benches. Users wishing to try Enabled Primitive subsystems in their design should be aware of these restrictions and use enabled primitive subsystems with caution.] There is a hard restriction however that the Enable block cannot be used in conjuction with Folding.
DSP Builder Advanced translates or 'sanitises' all names - blocks, subsystems, etc - into those that are valid VHDL, including the removal of special characters. The error message means that for the given name, once the special characters have been removed no characters are left. Remember that names should be kept short but descriptive and should ideally be restricted to letters and numbers (but not begin with a number). Reserved words in VHDL (the hardware language used for generation) should also be avoided - the tool will replace reserved words with the phrase "_rsrvd_fix" in the generated hardware. The list of reserved words includes:
abs, access, after, alias, and, architecture, array, assert, attribute, begin, block, body, buffer, bus, case, component, configuration, constant, disconnect, downto, else, elsif, end, entity, exit, file, for, function, generate, generic, group, guarded, if, impure, in, inertial, inout, is, label, library, linkage, literal, loop, map, mod, nand, new, next, nor, not, null, of, on, open, or, others, out, package, port, postponed, procedure, process, pure, range, record, register, reject, rem, report, return, rol, ror, select, severity, signal, shared, sla, sll, sra, srl, subtype, then, to, transport, type, unaffected, units, until, use, variable, wait, when, while, with, xnor, xor
The name of a block, or parameter could not be read. This can occur if special characters are used, or for names over 200 characters in length. Check that the blocks, subsystems and parameterization variables in your designs have sensible, short but descriptive names.
This message means that after sanitization two or more names in the same subsystem are now identical - both mapping to the same <new name>. For example If I had two blocks named "blockA$" and "blockA*", these would both be sanitized to just "blockA". As names within a hierarchical level have to be unique, the tool will stop generation until this is resolved by the user renaming the block(s).
Some operating systems can only cope with file name paths less than 256 characters. It is possible to exceed this if you a) are generating your model to a directory with an already long path name b) you have used long names for the subsystems in your DSPBA design (since the generated HDL is hierarchical). Try choosing an HDL output directory with a short path-name (set on the Control block). Also make sure the subsystem names used in your design are as short as possible while remaining both descriptive and unique within the same level of hierarchy.
The tool is attempting to perform the specified read / write operation to the specified file, but is prevented from doing so. This could arise, for example, if you already have the file open in a text editor, do not have the required permissions for the specified directory, or if the output directory cannot be created.
In generating the port list for the specified subsystem, the tool has identified that the specified signal name cannot be generated. The reasons for this can be that a) the first character is not a letter b) the name contains two or more consecutive underscores ("__"), c) the name is not alphanumeric, or d) the name ends in an underscore. Rename the specified signal name to avoid these errors.
In generating the port list for the specified subsystem, the tool has identified that the specified signal name cannot be generated as it is a VHDL reserved word. The list of reserved words includes:
abs, access, after, alias, and, architecture, array, assert, attribute, begin, block, body, buffer, bus, case, component, configuration, constant, disconnect, downto, else, elsif, end, entity, exit, file, for, function, generate, generic, group, guarded, if, impure, in, inertial, inout, is, label, library, linkage, literal, loop, map, mod, nand, new, next, nor, not, null, of, on, open, or, others, out, package, port, postponed, procedure, process, pure, range, record, register, reject, rem, report, return, rol, ror, select, severity, signal, shared, sla, sll, sra, srl, subtype, then, to, transport, type, unaffected, units, until, use, variable, wait, when, while, with, xnor, xor.
Rename the specified signal to somethign other than the words on the list above.
In generating the port list for the specified subsystem, the tool has identified that the specified signal name occurs more than once. This can arise if a singal name is repeated directly, or if multiple signals map to the same name once sanitized, or if multiple signals map to the same name once vector and complex type unrolling has been done (for example if you have a port a_1 and a vector port A (which would be unrolled to created a list of numbered ports). Note that the detection of name clashes is case-insensitive as VHDL (the output HDL language for generation) is case insensitive.
DSPBA serializes and caches the design. This is then used to compare against upon re-generation such that only changed subsystems are re-generated. The serialized design is stored as an XML file, and includes all the information required to regenerate - including for example subsystem latencies. The error message is displayed if there is a problem reading this file; perhaps due to some file corruption. A workaround would be to regenerate from scratch - deleting the XML file and the generated RTL directory to force the complete regeneration.
The specifed block has no 'ReferenceBlock' or 'AncestorBlock' parameter, so the tool doesn not know what to do with it. Check the block in question is legal.
Many of the numeric parameters specified on DSPBA blocks can only be specified using Matlabs default double type. If the parameter data type is not matlab double DSPBA will attempt to convert it, using the Matlab double() command. IF this fails however the error message will be displayed. Resolve by specifying the parameter as a Matble double data-type.
Some parameters can only accept integer values (i.e. whole numbers). The error message is diplayed if the specified parameter value is not an integer. The error can only be resolved by specifying an integer value.
This error is specific to use of the Simulink selector block. Hardware generation for this block is currently restricted to index by dialog, with index by port unsupported.
The underlying data-type used to specify an initialization parameter on the block <name> is unsupported. Note that in most cases numeric parameters have to be one of the basic Simulink types, that is: single, int32, uint32, int16, uint16, int8 uint8. Fixed point data-types are generally not supported for parameters.
The named BitExtract ModelPrim block has illegal 'Least Significant Bit Position from Input Word' parameter
The ForLoop block allow four different 'end of loop' criteria to be selected: <, <=, >, >= - yet the tool has detected that one not on this list has been selected. If this occurs it is likely that the block has become corrupted - perhaps broken from the library link and edited, and it is suggested that the user chaeck the ForLoop blocks in their design and if necessary delete and replace from the library.
A FIFO block has the incorrect number of values specified for the 'FIFO Setup' parameter. Generally three parameters should be specified as a vector: [<depth> <fill threshold> <full period>]. Check the settings on the FIFO blocks in the design.
Note that this rule applies generally to other Simulink blocks for which synthesis is supported (such as Muxes and Real-Imag To Complex). These blocks cannot be used to change the SampleTime of the system - as this will not be reflected in the generated hardware. The SampleTime parameters for such blocks must explicitly be set to -1.
This error is specific to the ModelPrim Demux block, a channel deserializer equivalent to a ModelPrim equivalent of the ChannelViewer block. The channel to be output includes a negative number, which will always be outside the supported range of channel numbers. Check and correct the parameterization of the highlighted demux block to resolve.
This error is specific to the ModelPrim Demux block, a channel deserializer equivalent to a ModelPrim equivalent of the ChannelViewer block. The channel to be output includes a channel number larger than the specified number of input channels. Check and correct the parameterization of the highlighted demux block to resolve.
Found DSPBA block <name> but no top level Control block. DSPBA designs must contain a Control block at the top hiearchical level of the Simulink model.
Found DSPBA block <name> but no top level Signals block. DSPBA designs must contain a Signals block at the top hiearchical level of the Simulink model.
This error is displayed when a ModelIP block (CIC, FIR, NCO, Scaler, Channel Viewer, etc) is found in a subsystem at the same hierarchical level or lower than a SynthesisInfo ModelPrim block. This usual cause is that the ModelIP block has been placed in a primitive subsystem - which is illegal in DSPBA. Alternatively a SynthesisInfo block could have been placed unnecessarily outside a primitive subsystem alongside the ModelIP block. Check for these to resolve the error.
This occurs when a hirearchy of subsystems contains multiple SynthesisInfo blocks, or ModelPrim boundary blocks. This is not supported, so check that no such blocks have been placed in <subsystem B> inadvertently.
The Nth input port of block <name> has been left unconnected. All input ports to DSPBA blocks must be conencted for generation and simulation to continue.
This error is diplayed when a ModelPrim block in one subsystem directly drives a ModelPrim block in another subsystem with no intervening ChannelIn or GPIn. Make sure the input to the driven primitive subsystem goes via a ChannelIn or GPIn block.
The specified ModelPrim GPIn boundary block must be driven directly from a Simulink subsystem input port block at the same level. Move any logic betweeen the specified block and the subsystem port to after the GPIn.
The specified ModelPrim GPOut boundary block must directly drive a single Simulink subsystem output port block at the same level. If necessary replicate the GPOut or use a ChannelOut.
Each output of the specified ModelPrim ChannelOut boundary block must directly drive a single Simulink subsystem output port block at the same level. Move any logic betweeen the specified block and the subsystem output port to before the ChannelOut .
DSPBA will attempt to pipeline to achieve the specified clock frequency. However, in this instance it has detected a clock frequency that it knows will be unobtainable for the device and speed grade specified. Note that currently the limit at which this error occurs is optimistic, so this should not be used as a general guide as to the maximum achievable fmax.
Add a Signals block from the Base Blocks library to the top level of the design. This block is required by DSPBA.
The Device block specifies the top synthesizable level of the design. This must be a subsystem below the top level of the model - such that the top level of the model contains the non-synthesizable test-bench and all the control and script blocks, such as Control, Signals, Run Quartus and Run ModelSim. Select the synthesizable part of your design and the Device block and create a subsystem with all these in.
Nested subsystems were found with device blocks. A subsystem hierarchy can contain at most one device block. Remove the device block from <subsystem B>.
The Control block at the top level of the design specifies a 'System Address Width', which is the bit-width to use for the address signal in the generated bus interface This has to be wide enough such that all the bus addresses specified within the synthesizable system (on ModelBus blocks and ModelIP blocks) can be addressed. If any address falls outside of the expressable range - as the start address and or depth is too large with an address signal only <width> bits wide - the error is displayed. To resolve the error check that your start addresses and memory depths are as you expect, and if so increase the 'System Address Width' on the Control block to the <required width>.
A run-time error was detected during simulation.
The automatic testbenches (ATBs) work by recording the Simulink simulation inputs and outputs (STMs) at each ChannelIn, ChannelOut, GPIn, GPOut and at each ModelIP input and output, then using these to drive and compare in a HDL testbench run in ModelSim. If the option to create Automatic testbenches is switched on in the Control block, then there have to be blocks in the design that will be recording the STM files. Follow the suggested action to resolve.
Community support is provided Monday to Friday. Other contact methods are available here.
Intel does not verify all solutions, including but not limited to any file transfers that may appear in this community. Accordingly, Intel disclaims all express and implied warranties, including without limitation, the implied warranties of merchantability, fitness for a particular purpose, and non-infringement, as well as any warranty arising from course of performance, course of dealing, or usage in trade.
