Success! Subscription added.
Success! Subscription removed.
Sorry, you must verify to complete this action. Please click the verification link in your email. You may re-send via your profile.
Simplified memory access commands for systems with only one memory master.
Command | Parameters | Description |
get_default_master | <none> | Returns the virtual filesystem path to the first Master found. |
write_memory | address, list-of-values | Using the default master, write the list-of-values to the given address . |
write_8 | address, list-of-values | Using the default master, write the list-of-values to the given address using only 8-bit byte accesses. |
write_16 | address, list-of-values | Using the default master, write the list-of-values to the given address using only 16-bit halfword accesses. |
write_32 | address, list-of-values | Using the default master, write the list-of-values to the given address using only 32-bit word accesses. |
read_memory | address, size-to-read | Using the default master, read and return the given number of bytes from the given address. |
read_8 | address, size-to-read | Using the default master, read and return the given number of bytes from the given address, using only 8-bit byte accesses. |
read_16 | address, size-to-read | Using the default master, read and return the given number of bytes from the given address, using only 16-bit halfword accesses. |
read_32 | address, size-to-read | Using the default master, read and return the given number of bytes from the given address, using only 32-bit word accesses. |
Community support is provided Monday to Friday. Other contact methods are available here.
Intel does not verify all solutions, including but not limited to any file transfers that may appear in this community. Accordingly, Intel disclaims all express and implied warranties, including without limitation, the implied warranties of merchantability, fitness for a particular purpose, and non-infringement, as well as any warranty arising from course of performance, course of dealing, or usage in trade.
