cancel
Showing results for
Search instead for
Did you mean:
836 Discussions
Design Example - Arria II GX DDR3 SDRAM ALTMEMPHY 300MHz x16
Last Major Update
Initial Release – October 2009 – Arria II GX DDR3 SDRAM x16 300MHz, Quartus II v9.1, DDR3 SDRAM High Performance Controller II with ALTMEMPHY, Arria II GX Development Kit.
Design Overview
This design is meant as a demo style lab. It very briefly covers the steps required to successfully get a DDR3 SDRAM interface working with a Arria II GX FPGA using a single Micron MT41J64M16LA-15E DDR3 SDRAM component on the Arria II GX Development Kit. The purpose of the lab is for the reader to get a basic feel for what steps are involved in getting an external memory working with an Altera FPGA and the ALTMEMPHY IP. The lab will not cover any of the steps in detail but simply show an overview of the design process.
The lab creates a 16 bit 300MHz DDR3 SDRAM external memory PHY and controller using Altera’s DDR3 SDRAM High Performance Controller II with ALTMEMPHY IP. The IP also generates an example top level file, an example driver, and a test bench including an external memory model. All these will be used to demonstrate the DDR3 SDRAM functionality
Design Specifications
The table below lists the specifications for this design:
AttributeSpecification
Quartus versionQuartusII v9.1
FPGAEP2AGX125EF35C4
KitArria II GX Development Kit
Memory deviceDDR3 SDRAM (Micron MT41J64M16LA-15E )
Memory speed667MHz
Memory topologyx16-bit, 1334-Mbps DDR3 SDRAM component
IP usedDDR3 SDRAM High Performance Controller II with ALTMEMPHY IP and generated example top Quartus project
Lab Steps
The lab uses Quartus II v9.1 and has Modelsim set up via NativeLink for simulation. The lab assumes the reader is a competent user of these tools and many of their features.
Four files have been pre-designed for this lab to save time.
  • A pin location assignments tcl script (ArriaIIGX_DDR3_PinLocations.tcl)
  • A signal tap file for debug of the interface design that has been created
  • A board trace model assignments script (ArriaIIGX_DDR3_BTModels.tcl)
  • A virtual pins assignments script for this design (ArriaIIGX_DDR3_exdriver_vpin.tcl)
A Quartus archive for the final project is also included for reference.
Files for this lab are located in this zip file – emi_ddr3_aiigx.zip
Create a new folder for the project and place the files in it
Design Generation
1. Use the Megawizard Plug-in Manager to generate a DDR2 SDRAM High Performance Controller
Copy the memory parameters files,ArriaIIGX_DDR3_Kit(MT41J64M16LA-15E).xml, to your <installation directory>\91\ip\ddr2_high_perf\lib directory.
Start Quartus, open MegaWizard Plug-In Manager and create a new variation.
  • In the Megawizard GUI, set device family to be Arria II GX
  • The IP is located under the folders Interfaces/External Memory/DDR3 SDRAM, choose DDR3 SDRAM High Performance Controller v9.1
  • If your license for ModelSim can not support multiple HDL languages then choose verilog as output file type
  • For the name of the output file, browse to the folder you created above, give the instance the name “ddr3”, click Open, click Next to open the IP GUI
2. Set parameters for Memory Controller with ALTMEMPHY
  • General Settings Tab
  1. Set Speed grade to 4
  2. Set PLL reference clock frequency to 100 MHz.
  3. Set Memory clock frequency to 300 MHz
  4. For Memory Presets, select ArriaIIGX_DDR3_Kit(MT41J64M16LA-15E) which gives a 16-bit wide, 1334-Mbps 667-MHz
  5. Turn on the Enable Memory Chip Calibration in Timing Analysis option in the Advanced page of Memory Preset Editor. This option is required for Arria II GX devices, which need post-processing script to remove timing model pessimism
  • PHY Settings Tab
  1. Turn on Use differential DQS option under Advanced PHY
  2. Under Address/Command Clock Settings, for Dedicated clock phase type 90
  • Board Settings Tab
  1. Enter following values under Slew Rates:
               ■ CK/CK# slew rate (Differential) = 4V/ns
              ■ Addr/Command slew rate = 2 V/ns
              ■ DQS/DQS# slew rate (Differential) = 1.8 V/ns
              ■ DQ slew rate = 1.5 V/ns
     2. Enter following values under Board Skews:
            ■ Max skew within DQS group = 0.020 ns
            ■ Max skew between DQS groups = 0.020 ns
             ■ Addr/Command to CK skew = -0.045s
    3. The Intersymbol Interference parameters are not applicable for single rank configurations. Set all these parameters to 0 ns
  • Controller Settings Tab
1. Set High Performance Controller II as Controller Architecture for higher efficiency and advanced features.
2. Under Efficiency, select the specified values for the following options:
   a. For Command Queue Look-Ahead Depth, select 6.
   b. For Local-to-Memory Address Mapping, select CHIP-ROW-BANK-COL.
   c. For Local Maximum Burst Count, select 4.
3. Click Next.
4. Turn the Generate simulation model option.Click “Finish” to start IP generation. Check important messages during generation. After IP is successfully generated, click Exit to close GUI. The ALTMEMPHY megafunction is instantiated automatically.
3. Set Top-Level Entity
The Megawizard generates a Quartus example top project. This project connects an example driver to the controller interface so users can quickly compile and test their ALTMEMPHY IP configuration on hardware.
  • Open the top-level entity file, <variation_name>_example_top.v or vhd
  • On the Project menu click Set as Top-Level Entity
4. Perform Analysis and Synthesis
This step is required so Quartus can determine the names of the external ports connected to the ALTMEMPHY for when the I/O assignments are created in the next step.
5. Set Optimization Technique
This step is required to ensure the remaining unconstrained paths are routed with the highest speed and efficiency. To set the optimization technique, perform the following steps:
  • On the Assignments menu, click Settings
  • Select Analysis & Synthesis Settings
  • Select Speed under Optimization Technique. Click OK
6. Set Fitter Effort
To set the fitter effort, perform the following steps:
  • Select Fitter Settings
  • Turn on Optimize hold timing and select All Paths
  • Turn on Optimize multi-corner timing
  • Select Standard Fit (highest effort) under Fitter effort
  • Click OK
7. Add Timing Constraints
To add timing constraints, perform the following steps:
  • On the Assignments menu click Settings.
  • In the Category list, expand Timing Analysis Settings, and select TimeQuest
  • Timing Analyzer.
  • Select the <variation_name>_phy_ddr_timing.sdc file and click Add.
  • Click OK.
8. Assign the pin and DQ group settings
Run the tcl script <variable_name>_pin_assignments.tcl to assign the pin and DQ group assignments. This tcl script is generated for you by the IP megawizard
  • Verify in the Assignment Editor that pin assignments have been created successfully
9. Assign the pin locations
Pin locations for external memory systems are not automatically created.
  • Run the ArriaIIGX_DDR3_PinLocations.tcl script to assign pin locations for the targeted kit
  • Run the ArriaIIGX_DDR3_exdriver_vpin.tcl script to assign virtual pins
  • Verify in Pin Planner or Assignment Editor that pin locations have been created successfully
10. Assign I/O Standards
To assign the I/O standards, perform the following steps:
  • On the Assignments menu, click Assignment Editor.
  • Specify LVDS as the I/O standard for clock_source.
  • Specify 1.5 V as the I/O standard for global_reset_n.
11. Enter board trace models
  • Run the ArriaIIGX_DDR3_BTModels.tcl script to enter the board trace model for the targeted kit
12. Do a Full Compile
This should take about 10 minutes depending on the compiling PC.
Design Analysis
1. Timing Analysis results
  • In the Compilation Report, Time Quest Timing Analyzer folder expand the three VT model folders, and the Report DDR folder
- Check the summary at the bottom of that report
- Check that all set up and hold timings pass
Note: there will be some unconstrained paths in the design. These are associated with the example driver that will not be part of a fully integrated HP controller design.
2. On board debug with Signal Tap
Open the Signal Tap file and reset the .sof file to the one just created with the full compilation
  • Program the kit FPGA with the .sof
  • Run Signal Tap Analysis
  • - Restart the driver
   - Ensure that test complete goes high (signal tap is trigger on this), this is the end of the driver testing, check the driver's pass signal is high.
   - Also check that calibration was successful and that the PLL is locked
Design Simulation
  • Run EDA RTL Simulation from Tools Menu – Run EDA Simulation Tool -> EDA RTL Simulation
  - The simulation will stop once the test complete signal goes high in the test bench
  - CLICK “NO” WHEN ASKED IF YOU WANT TO FINISH, otherwise simulation will be reset
  - Observe the results in the ModelSim Wave window
Notes/Comments
For a list of supported and unsupported features in the DDR3 SDRAM Controller with ALTMEMPHY, refer to the Altera's External Memory Interface Handbook. For more information about Altera’s current IP offering, refer to Altera’s Intellectual Property website.
Update History
See Also
1. List of designs using Altera External Memory IP
External Links
1. Altera's External Memory Interface Solutions Center
2. Altera's External Memory Interface Handbook
Version history
Last update:
‎06-25-2019 11:20 PM
Updated by:
Contributors
