Community
cancel
Showing results for
Search instead for
Did you mean:
Design Example - Custom PHY IP w/ PMA Controls Reconfiguration (Stratix V GX)
(Redirected from Design Example - Custom PHY IP w/ PMA Controls Reconfiguration)
External Links
Altera Transceiver PHY IP Core User Guide (PDF)
Altera Stratix V Device Documentation
Altera Avalon Memory-Mapped Interface Specification (PDF)
Design File
for Quartus II v11.0
Altera Stratix V Custom PHY IP PMA reconfiguration v11.0 (ZIP)
for QuartusII v13.1
Altera Stratix V Custom PHY IP PMA reconfiguration v13.1 (ZIP)
Design Specifications
The table below lists the specifications for this design:
AttributeSpecification
Device FamilyStratix V GX
FPGA5SGXMA7K2F40C2
Quartus versionQuartusII v11.0, b157
Modelsim versionModelsim SE v6.6d
Datarate3.125Gbps
Data patternPRBS 23
Number of channels
IP usedCustom PHY IP, Traceiver Reconfiguration Controller
The table below lists the specifications for the design for v13.1:
FPGA5SGXMA7K2F40C2
Quartus versionQuartusII v13.1 b162
Modelsim versionModelsim SE v10.0d
Datarate3.125Gbps
Data patternPRBS 23
Number of channels
Design Overview
This design implements the following blocks:
  1. Two Custom PHY IP instances
  2. One Transceiver Reconfiguration Controller
  3. PRBS Generator
  4. PRBS Checkers
  5. Avalon Memory-Mapped (MM) Masters
  6. Reconfiguration Controller Avalon Memory-Mapped (MM) Master
8/88/SV_custom_PMA_reconfig.jpg ( SV custom PMA reconfig.jpg - click here to view image )
Compilation in Quartus
1) Download and unzip the zip files linked above into a folder to be used as the download directory.
2) Open the project file (.qpf) by going to File > Open Project and navigating to <download_directory>\SV_Custom_PMA_Reconfig\source. Open top.qpf.
3) Use the Megawizard Plug-in Manager to generate Altera Generated IP
Before compiling you must regenerate the Altera generated IP using the Megawizard. You will perform this step twice - once for the top_custom.v and once for the top_reconfig.v. Open MegaWizard Plug-In Manager and choose edit a variation.
  • Select the IP you want to edit and generate (The .v file will be located in your project directory).
  • If your license for ModelSim can not support multiple HDL languages then chose verilog as output file type (The default settings will work for this example).
  • Select the options for the IP you want to generate (The default settings will work for this example), and click Finish.
After the previous steps have been completed, you can compile the entire design by going to Processing > Start > Start Analysis and Synthesis.
4) During compilation you can expect following critical warnings
  • Critical Warning (18061): Ignored Power-Up Level option on the registers
  • Critical Warning: Synopsys Design Constraints File file not found: 'top.sdc'. A Synopsys Design Constraints File is required by the TimeQuest Timing Analyzer to get proper timing constraints. Without it, the Compiler will not properly optimize the design.
  • Critical Warning (169085): No exact pin location assignment(s) for 39 pins of 39 total pins.
  • Critical Warning: Timing requirements not met.
Simulation Guidelines
The attached zip file has all the required design and simulation files. To start the simulation, launch Modelsim and source phy_sim_top.tcl
Update History
  1. Initial Release - May 16 2011
 See Also
  1.  Transceiver design examples
Key Words
Stratix V, Custom PHY IP, Tranceiver Reconfiguration Controller, PMA reconfiguration, dynamic reconfiguration, analog reconfiguration, transcevier reconfiguration, xcvr reconfiguration, Stratix V GX, Stratix V GT, SV, SVGX, SVGT, S5GX, S5GT, S5, Stratix 5, Stratix 5 GX, StratixV, StratixV GX, Stratix5, Stratix5 GX
© 2010 Altera Corporation. The material in this wiki page or document is provided AS-IS and is not
supported by Altera Corporation. Use the material in this document at your own risk; it might be, for example, objectionable,
misleading or inaccurate.Retrieved from http://www.alterawiki.com/wiki/Altera_Wiki
Version history
Revision #:
1 of 1
Last update:
‎06-25-2019 11:22 PM
Updated by:
Contributors
