cancel
Showing results for
Search instead for
Did you mean:
836 Discussions
Design Example - SIII ALTMEMPHY RLDRAMII 300MHz x18- SIO
Last Major Update
Initial Release - November 18th 2010 - SIII ALTMEMPHY RLDRAMII 300MHz, 2 x18 devices, QuartusII v8.1
Design Overview
This design has two x18 RLDRAM II devices running at 300MHz on SIO. This design is used to migrate an RLDRAMII design from a SII to a SIII device.
Design Specifications
Design files are located here.
The table below lists the specifications for this design:
AttributeSpecifcation
Quartus versionQuartusII v8.1
FPGAEP3S150F1150
KitNA
Memory deviceRLDRAMII
Memory speed300MHz
Memory topologyTwo x18 devices
IP usedALTMEMPHY
Notes/Comments
Update History
  1. November 18th 2010 - SIII ALTMEMPHY RLDRAMII 300MHz, 2 x18 devices, QuartusII v8.1
See Also
  1.   List of designs using Altera External Memory IP
External Links
  1. Altera's External Memory Interface Solutions Center
  2. Altera's External Memory Interface Handbook
Key Words
ALTMEMPHY, RLDRAMII, Design Example, External Memory, Stratix III, SIII
© 2010 Altera Corporation. The material in this wiki page or document is provided AS-IS and is not
supported by Altera Corporation. Use the material in this document at your own risk; it might be, for example, objectionable,
misleading or inaccurate.Retrieved from http://www.alterawiki.com/wiki/Altera_Wiki
Contents
 [hide
Version history
Last update:
‎06-25-2019 04:57 PM
Updated by:
Contributors
