cancel
Showing results for
Search instead for
Did you mean:
Design Example - SIII ALTMEMPHY RLDRAMII 300MHz x72
5 / 5 (1 vote cast)
Last Major Update
Initial Release - November 18th 2010 - SIII ALTMEMPHY RLDRAMII 300MHz, x72 interface (2 x36), QuartusII v8.1
Design Overview
This design has a x72 RLDRAM II controller running at 300MHz. This design is used to migrate an RLDRAMII design from a SII to a SIII device.
Design Specifications
Design files are located here
The table below lists the specifications for this design:
AttributeSpecifcation
Quartus versionQuartusII v8.1
FPGAEP3SL150F1152
KitNA
Memory deviceRLDRAMII
Memory speed300MHz
Memory topologyTwo x36 devices
IP usedALTMEMPHY
Notes/Comments
Update History
  1. November 18th 2010 - SIII ALTMEMPHY RLDRAMII 300MHz, x72 interface (2 x36), QuartusII v8.1
See Also
  1.   List of designs using Altera External Memory IP
External Links
  1. Altera's External Memory Interface Solutions Center
  2. Altera's External Memory Interface Handbook
Key Words
ALTMEMPHY, RLDRAMII, Design Example, External Memory, Stratix III, SIII
© 2010 Altera Corporation. The material in this wiki page or document is provided AS-IS and is not
supported by Altera Corporation. Use the material in this document at your own risk; it might be, for example, objectionable,
misleading or inaccurate.Retrieved from http://www.alterawiki.com/wiki/Altera_Wiki
Version history
Last update:
‎06-27-2019 03:57 PM
Updated by:
Contributors
