cancel
Showing results for
Search instead for
Did you mean:
836 Discussions
Design Example - SIV ALTMEMPHY DDR3 400MHz - Four Controllers
4 / 5 (1 vote cast)
Last Major Update
Initial Release - November 11th 2010 - SIV ALTMEMPHY DDR3 400MHz, four x72 independent interfaces, QuartusII v8.0SP1
Design Overview
This design shows 4 x72 DDR3 SDRAM DIMM high-performance controllers fitting in a EP4SGX530 F1932 package. No resources are shared in this design. This design is to show that four DIMMs can fit in one FPGA and to also show how to stamp out four exact controllers with one ALTMEMPHY instantiation. The SDC and report_timing.tcl will be able to constrain and report the timing result for all four controllers without additional work.
This design has not been simulated or tested on the board.
Design Specifications
Design files are located here.
The table below lists the specifications for this design:
AttributeSpecifcation
Quartus versionQuartusII v8.0SP1
FPGAEP4SGX530F1932
KitNA
Memory deviceDDR3
Memory speed400MHz
Memory topologyFour x72 independent interfaces
IP usedALTMEMPHY
Notes/Comments
Update History
  1. Initial Release - November 11th 2010 - SIV ALTMEMPHY DDR3 400MHz, four x72 independent interfaces, QuartusII v8.0SP1
See Also
  1.   List of designs using Altera External Memory IP
External Links
  1. Altera's External Memory Interface Solutions Center
  2. Altera's External Memory Interface Handbook
Key Words
ALTMEMPHY, DDR3, Design Example, External Memory, Multiple Controllers, Stratix IV, SIV
© 2010 Altera Corporation. The material in this wiki page or document is provided AS-IS and is not
supported by Altera Corporation. Use the material in this document at your own risk; it might be, for example, objectionable,
misleading or inaccurate.Retrieved from http://www.alterawiki.com/wiki/Altera_Wiki
Version history
Last update:
‎06-27-2019 04:08 PM
Updated by:
Contributors
