cancel
Showing results for
Search instead for
Did you mean:
836 Discussions
Design Example - SIV ALTMEMPHY DDR3 533MHz x64 - SIVGX Development Kit
5 / 5 (1 vote cast)
Last Major Update
Initial Release - November 18th 2010 - SIV ALTMEMPHY DDR3 533MHz, QuartusII v9.0SP 0.03
Design Overview
This design shows a DDR3 SDRAM DIMM high-performance controller fitting in a EP4SGX230 KF40 package. The design includes SignalTapII and DebugGUI.
Design Specifications
Design files are located here.
The table below lists the specifications for this design:
AttributeSpecifcation
Quartus versionQuartusII v9.0SP 0.03
FPGAEP4SGX230KF40
KitStratix IV GX Development Kit
Memory deviceDDR3
Memory speed533MHz
Memory topologyOne DDR3 SDRAM x64 interface
IP usedALTMEMPHY
Notes/Comments
Update History
  1. Initial Release - November 18th 2010 - SIV ALTMEMPHY DDR3 533MHz, QuartusII v9.0SP 0.03
See Also
  1.   List of designs using Altera External Memory IP
External Links
  1. Altera's External Memory Interface Solutions Center
  2. Altera's External Memory Interface Handbook
Key Words
ALTMEMPHY, DDR3, Design Example, External Memory, Stratix IV GX, SIV GX
© 2010 Altera Corporation. The material in this wiki page or document is provided AS-IS and is not
supported by Altera Corporation. Use the material in this document at your own risk; it might be, for example, objectionable,
misleading or inaccurate.Retrieved from http://www.alterawiki.com/wiki/Altera_Wiki
Version history
Last update:
‎06-27-2019 04:12 PM
Updated by:
Contributors
