cancel
Showing results for
Search instead for
Did you mean:
836 Discussions
Design Example - SIV ALTMEMPHY RLDRAMII 400MHz x18 - Eight Controllers
5 / 5 (1 vote cast)
Last Major Update
Initial Release - November 18th 2010 - SIVGX ALTMEMPHY RLDRAMII 400MHz, eight x18 interfaces, QuartusII v8.1
Design Overview
This design has 8 RLDRAM II controllers, 4 on the top and 4 on the bottom of the device. The PLL has been pulled out from inside the PHY to the top level of the Quartus II project. This design has one DLL and one PLL shared per 4 controllers. Since all 8 controllers have the same spec, this design uses one variation of the RLDRAM II reference design and instantiate it 8 times. This design is for fitting and timing closure purpose only, as in reality, the example driver for each controller will be different. Also, multiplexed address is used for this design. This design is not simulated or tested on a board.
Design Specifications
Design files are located here.
The table below lists the specifications for this design:
AttributeSpecifcation
Quartus versionQuartusII v8.1
FPGAEP4SGX230KF40
KitNA
Memory deviceRLDRAMII
Memory speed400MHz
Memory topologyEight x18 devices
IP usedALTMEMPHY
Notes/Comments
Update History
  1. Initial Release - November 18th 2010 - SIVGX ALTMEMPHY RLDRAMII 400MHz, eight x18 interfaces, QuartusII v8.1
See Also
  1.   List of designs using Altera External Memory IP
External Links
  1. Altera's External Memory Interface Solutions Center
  2. Altera's External Memory Interface Handbook
Key Words
ALTMEMPHY, RLDRAMII, Design Example, External Memory, Stratix IV GX, SIV GX
© 2010 Altera Corporation. The material in this wiki page or document is provided AS-IS and is not
supported by Altera Corporation. Use the material in this document at your own risk; it might be, for example, objectionable,
misleading or inaccurate.Retrieved from http://www.alterawiki.com/wiki/Altera_Wiki
Version history
Last update:
‎06-27-2019 04:12 PM
Updated by:
Contributors
