Success! Subscription added.
Success! Subscription removed.
Sorry, you must verify to complete this action. Please click the verification link in your email. You may re-send via your profile.
For an external memory interface, the DQ, DQS, DQSn, DM, ADDR[14:0], BA[2:0], CK, CK_N, CK_E, CS_N, RAS_N, CAS_N, WE_N, and ODT pins must be connected to I/O buffers via the ALTIOBUF megafunction. There are 14 interface signals for this design example that need I/O buffers to be interfaced with the FPGA pins. These I/O buffers are contained in the dqs_io_buffer, ck_io_buffer, dq_io_buffer, dm_io_buffer, addr_io_buffer, ba_io_buffer, and cmd_io_buffer instances. There are 35 I/O buffers used in this instance. Table 2–10 shows the requirements that must be set for these signals in the I/O buffer instances.
Signal | Instance | Requirement |
DQS and DQS_N | dqs_io_buffer | 1-bit bidirectional I/O buffer with differential capabilities enabled |
CK and CK_N | ck_io_buffer | 2-bit output I/O buffer with differential capabilities enabled |
DQ[7:0] | dq_io_buffer | 8-bit bidirectional I/O bufferI/O buffer |
DM | dm_io_buffer | 1-bit output I/O buffer |
ADDR[14:0] | addr_io_buffer | 15-bit output I/O buffer |
BA[2:0] | ba_io_buffer | 3-bit output I/O buffer |
CK_E | cmd_io_buffer | 1-bit output I/O buffer |
CS_N | cmd_io_buffer | 1-bit output I/O buffer |
RAS_N | cmd_io_buffer | 1-bit output I/O buffer |
CAS_N | cmd_io_buffer | 1-bit output I/O buffer |
WE_N | cmd_io_buffer | 1-bit output I/O buffer |
ODT | cmd_io_buffer | 1-bit output I/O buffer |
Because this is a custom external memory interface for DDR2 interface, you must design the necessary datapath to control the CK, CK_N, ADDR[14:0], BA[2:0], CK_E, CS_N, RAS_N, CAS_N, WE_N, and ODT signals. Altera provides a design example that you can use to create your own logic. In the Altera-provided design example, the datapath of the CK and CK_N signals are controlled by the mem_clock_generate instance. This instance consists of two DDIO_OUT blocks. For the CK signal, the inputs of the DDIO_OUT block are each tied to VCC and GND. For the CK_N signal, the inputs of the DDIO_OUT block are each tied to GND and VCC to reflect the inverse of the CK signal. The addr_cmd_generate instance controls the datapath of the ADDR[14:0], BA[2:0], CK_E, CS_N, RAS_N, CAS_N, WE_N, and ODT signals. This ddr_cmd_generate instance consists of 24 DDIO_OUT blocks to individually represent the 24 signals. For these signals, there are 24 DFF blocks to control their respective OE (output enable) signals. The OE signals are controlled by the addr_cmd_generate_oe instance. The inputs of these 48 blocks are fed accordingly with data, depending on the three state machines that act as the control path of the customized memory controller. The three state machines are as follows:
There are two multiplexer instances: cmd_addr_mux_1 and dqs_dqsn_dq_dm_mux_1.
cmd_addr_mux_1
The cmd_addr_mux_1 instance is a 144-bit to 72-bit multiplexer with a 1-bit select signal. The cmd_addr_mux_1 instance multiplexes the CK_E, CK_N, RAS_N, CAS_N, WE_N, BA_OE, BA_DATA, ADDR_OE, ADDR_DATA and ODT signals from the following two control path state machines of the customized memory controller:
The output of the multiplexer is sent to the data path of the command and address instances, addr_cmd_generate and addr_cmd_generate_oe. For this multiplexer, the control_driver_ddr instance controls the 1-bit select.
dqs_dqsn_dq_dmr_mux_1
The dqs_dqsn_dq_dmr_mux_1 instance is a 66-bit to 33-bit multiplexer with a 1-bit select signal. The dqs_dqsn_dq_dmr_mux_1 instance multiplexes the dm_oe, dm_data, dq_oe, dq_data, dqs_oe, dqs_data, dqsn_oe, and dqsn_data signals from the following two control path state machines of the customized memory controller:
The output of the multiplexer is sent to the data path of the DQS, DQSN, DQ, and DM (ALTDQ_DQS instance), which is the altdq_dqs_1 instance. The 1-bit select for this multiplexer is controlled by the control_driver_ddr instance. This completes the steps for the customized memory controller datapath logic to generate the CK,CK_N, ADDR[14:0], BA[2:0], CK_E, CS_N, RAS_N, CAS_N, WE_N, and ODT signals.
Because this is a custom external memory interface for the DDR and DDR2 interface, you must design control path logic to control the DQS, DQS_N, DQ, DM, A (address), BA (bank address), CK, CK#, CKE, CS#, RAS#, CAS#, WE#, and ODT signals from the FPGA core. The design example contains three state machines to control these signals to enable proper operation of the external memory interface. These state machines are as follows:
The control_init_ddr instance initializes the DDR2 component for the proper interface operation following the timing requirements as specified in the specific Micron DDR2 datasheet. Because the ALTMEMPHY megafunction does not support a burst length of 8, the customized memory controller in this design example initialized the DDR2 for this mode of operation.
The control_write_ddr instance writes a set of 8 data to the memory array in the DDR2 component following the timing requirements as specified in the specific Micron DDR2 datasheet.
The control_driver_ddr instance coordinates the two state machines (control_init_ddr and control_write_ddr instances) following the timing requirements as specified in the specific Micron DDR2 datasheet to enable proper operation of this design example. This includes sequentially enabling the following instances:
The state machine also controls the select signals of the two multiplexers (cmd_addr_mux_1 and dqs_dqsn_dq_dm_mux_1) depending on which of the two control path state machine is currently active.
After instantiating the necessary instances to create a customized DDR2 memory controller from the “Instantiate PHY (via ALTDLL and ALTDQ_DQS) and (Custom-Designed) Controller in a Quartus II Project” stage, you must generate the constraints files for the design example. Apply these constraints to the design before compilation. You must manually specify constraints because this design example does not use the ALTMEMPHY megafunction or the DDR2 SDRAM high-performance controller.
When you instantiate the customized DDR2 memory controller design, it does not automatically generate a timing constraint file (SDC file). You must manually create your own SDC file to constrain the timing on this design. This design example comes with a timing constraints file, top_custom_ddr2_controller_phy_ddr_timing.sdc. The timing constraint file constrains the clocks on the customized DDR2 memory controller design. To add timing constraints, perform the following steps:
To ensure the remaining unconstrained paths are routed with the highest speed and efficiency, set the optimization technique to Speed. To set the optimization technique, perform the following steps:
To set the Fitter effort to Standard Fit, perform the following steps:
To enter the pin location assignments, perform the following steps:
<note> If you are at the design exploration phase of your design cycle and do not have any PCB defined pin locations, you should still manually define an initial set of pin constraints, which can become more specific during your development process.
To manually assign pin locations, perform the following steps:
a. To select the device DQS pin groups that the design uses, assign each DQS pin in your design to the required DQS pin in the Pin Planner. The Quartus II Fitter then automatically places the respective DQ signals onto suitable DQ pins within each group. To see the DQS groups in Pin Planner, right click, select Show DQ/DQS Pins, and click In ×8/×9 Mode. Pin Planner shows each DQS group in a different color and with a different legend: S = DQS pin, Sbar = DQSn pin, and Q = DQ pin.
<note> Most DDR2 SDRAM devices operate in ×8/×9 mode. However, some DDR2 SDRAM devices operate in ×4 mode. Refer to your specific memory device datasheet.
b. Select the DQ mode to match the DQ group width (number of DQ pins/number of DQS pins) of your memory device. DQ mode is not related to the memory interface width.
<note> The DQ group order and DQ pin order in each group is not important. However, you must place DQ pins in the same group as their respective strobe pin.
<note> You must place CK and CK_N on a DIFFIO_RX pin pair, if your design uses differential DQS signaling.
For accurate I/O timing analysis, you must specify the board trace and loading information. This information should be derived and refined during your PCB development process of pre-layout (line) simulation and finally post-layout (board) simulation.
Before compiling the design, set the top-level entity of the project. The design example top-level file is top_custom_ddr2_controller.v, which connects 13 other sub-modules or instances for a complete customized memory controller for DDR2.
To set the top-level file, perform the following steps:
To compile the design, on the Processing menu, click Start Compilation. After successfully compiling the design, run the TimeQuest timing analyzer to verify the timing based on the SDC file. If the timing margin report shows negative hold time on the address and command datapath, adjusting the clock that is regulating the address and command output registers can improve the hold margin on the address and command datapath.
After you have compiled your design, set up and simulate the design in the ModelSim-Altera software by performing the following steps:
'define sg3
'define ×8
'define MAX_MEM
The three define statements prepare the DDR2 SDRAM interface model.
The first statement specifies the memory device speed grade as –3.
The second statement specifies the memory device width per DQS.
The third statement says to allocate memory for every address supported by the DDR2 model.
Original copy of EMI HB Volume 5 Chapter 1: Implementing Custom Memory Interface PHY
Design Example Files
Initial Release: July 2011.
ALTDQ_DQS, DDR2, SDRAM, Design Example, External Memory, EMI, Stratix III, SIII
Community support is provided Monday to Friday. Other contact methods are available here.
Intel does not verify all solutions, including but not limited to any file transfers that may appear in this community. Accordingly, Intel disclaims all express and implied warranties, including without limitation, the implied warranties of merchantability, fitness for a particular purpose, and non-infringement, as well as any warranty arising from course of performance, course of dealing, or usage in trade.
