Initial Release – December 2010 – Stratix III DDR3 SDRAM x72 533MHz, Quartus II v9.1, DDR3 SDRAM High Performance Controller II with ALTMEMPHY, Stratix III Memory Demonstration Kit.
This design is meant as a demo style lab. It very briefly covers the steps required to successfully get a DDR3 SDRAM interface working with a Stratix III FPGA using a single Micron MT9JSF12872AY-1G1BZES unbuffered DIMM on the Stratix III Memory Demonstration Kit. The purpose of the lab is for the reader to get a basic feel for what steps are involved in getting an external memory working with an Altera FPGA and the ALTMEMPHY IP. The lab will not cover any of the steps in detail but simply show an overview of the design process.
The lab creates a 72 bit 533MHz DDR3 SDRAM external memory PHY and controller using Altera’s DDR3 SDRAM High Performance Controller II with ALTMEMPHY IP. The IP also generates an example top level file, an example driver, and a test bench including an external memory model. All these will be used to demonstrate the DDR3 SDRAM functionality
The table below lists the specifications for this design:
Attribute | Specification |
Quartus version | QuartusII v9.1 |
FPGA | EP3SL150F1152-C2ES |
Kit | Stratix III Memory Demonstration Kit |
Memory device | DDR3 SDRAM (Micron MT9JSF12872AY-1G1BZES) |
Memory speed | 533MHz |
Memory topology | x72-bit, 1152-Mbps DDR3 unbuffered DIMM |
IP used | DDR3 SDRAM High Performance Controller II with ALTMEMPHY IP and generated example top Quartus project |
The lab uses Quartus II v9.1 and has Modelsim set up via NativeLink for simulation. The lab assumes the reader is a competent user of these tools and many of their features.
Four files have been pre-designed for this lab to save time.
• A pin location assignments tcl script (S3_MB1_DDR3_PinLocations.tcl)
• A signal tap file for debug of the interface design that has been created
• A board trace model assignments script (S3_MB1_DDR3_BTModels.tcl)
• A virtual pins assignments script for this design (S3_MB1_ddr3_exdriver_vpin.tcl)
A Quartus archive for the final project is also included for reference.
Files for this lab are located in this zip file – emi_ddr3_siii.zip
Create a new folder for the project and place the files in it
1. Use the Megawizard Plug-in Manager to generate a DDR3 SDRAM High Performance Controller
Copy the memory parameters files, S3MB1_Derated (Micron MT9JSF12872AY-1G1BZES).xml, to your <installation directory>\91\ip\ddr3_high_perf\lib directory.
Start Quartus, open MegaWizard Plug-In Manager and create a new variation.
2. Set parameters for Memory Controller with ALTMEMPHY
■ Address and command = 1.5 V/ns
■ CLK and CLK# = 3 V/ns (differential)
■ DQ = 2 V/ns
■ DQS = 3 V/ns (differential)
Hence, the correct tIS, tIH, tDS, and tDH values for this design are:
■ tIS = tISb + ΔtIS + (VIHAC – VREF)/address and command rising slew rate
=125 + 59 + 175/1.5 = 301 ps
■ tIH = tIHb + ΔtIH + (VREF – VILDC)/address and command rising slew rate
= 200 + 34 + 100/1.5 = 301 ps
■ tDS = tDSb + ΔtDS + (VIHAC – VREF)/DQ rising slew rate
= 25 + 88 + 175/2 = 201 ps
■ tDH = tDHb + ΔtDH + (VREF – VILDC)/DQ rising slew rate
= 100 + 50 + 100/2 = 200 ps
6. To set the ODT settings for the DDR3 SDRAM interface on your board, in the Preset Editor dialog box, select Memory Initialization Options.
7. In the Memory Initialization Options dialog box, perform the following steps:
a. For Output driver impedance, select RZQ/7 (which is 34).
b. For Dynamic ODT (Rtt_WR) value, select Dynamic ODT off.
c. For ODT Rtt nominal value, select RZQ/4 (which is 60).
d. Click OK to apply the settings and exit the dialog box.
1. Set High Performance Controller II as Controller Architecture for higher efficiency and advanced features.
2. Under Efficiency, select the specified values for the following options:
a. For Command Queue Look-Ahead Depth, select 6.
b. For Local-to-Memory Address Mapping, select CHIP-ROW-BANK-COL.
c. For Local Maximum Burst Count, select 4.
3. Click Next.
4. Turn the Generate simulation model option.Click “Finish” to start IP generation. Check important messages during generation. After IP is successfully generated, click Exit to close GUI. The ALTMEMPHY megafunction is instantiated automatically.
3. Set Top-Level Entity
The Megawizard generates a Quartus example top project. This project connects an example driver to the controller interface so users can quickly compile and test their ALTMEMPHY IP configuration on hardware.
4. Perform Analysis and Synthesis
This step is required so Quartus can determine the names of the external ports connected to the ALTMEMPHY for when the I/O assignments are created in the next step.
5. Set Optimization Technique
This step is required to ensure the remaining unconstrained paths are routed with the highest speed and efficiency. To set the optimization technique, perform the following steps:
6. Set Fitter Effort
To set the fitter effort, perform the following steps:
7. Add Timing Constraints
To add timing constraints, perform the following steps:
8. Assign the pin and DQ group settings
Run the tcl script ddr3_dimm_pin_assignments.tcl to assign the pin and DQ group assignments. This tcl script is generated for you by the IP megawizard
9. Assign the pin locations
Pin locations for external memory systems are not automatically created.
10. Assign I/O Standards
To assign the I/O standards, perform the following steps:
11. Enter board trace models
12. Advanced I/O Timing
ALTMEMPHY-based designs assume that the memory address and command signals are matched length to the memory clock signals. Typically, this length match is not true for DIMM-based designs. You should verify the difference in your design. For the Stratix III development board fitted with the Micron MT9JSF12872AY-1G1BZES DIMM, the address and command signals remain asserted 300 ps shorter than the clock signals.
set(additional_addresscmd_tpd) 0.000
set(additional_addresscmd_tpd) -0.300
13. Do a Full Compile
This should take about 10 minutes depending on the compiling PC.
1. Timing Analysis results
- Check the summary at the bottom of that report
- Check that all set up and hold timings pass
Note: there will be some unconstrained paths in the design. These are associated with the example driver that will not be part of a fully integrated HP controller design.
2. On board debug with Signal Tap
Open the Signal Tap file and reset the .sof file to the one just created with the full compilation
- Ensure that test complete goes high (signal tap is trigger on this), this is the end of the driver testing, check the driver's pass signal is high.
- Also check that calibration was successful and that the PLL is locked
- The simulation will stop once the test complete signal goes high in the test bench
- CLICK “NO” WHEN ASKED IF YOU WANT TO FINISH, otherwise simulation will be reset
- Observe the results in the ModelSim Wave window
For a list of supported and unsupported features in the DDR3 SDRAM Controller with ALTMEMPHY, refer to the DDR3 SDRAM Controller with ALTMEMPHY IP User Guide. For more information about Altera’s current IP offering, refer to Altera’s Intellectual Property website.
1. List of designs using Altera External Memory IP
1. Altera's External Memory Interface Solutions Center
2. Altera's External Memory Interface Handbook
ALTMEMPHY, DDR3 SDRAM, Design Example, External Memory , Stratix III, SIII
