Success! Subscription added.
Success! Subscription removed.
Sorry, you must verify to complete this action. Please click the verification link in your email. You may re-send via your profile.
first operand | second operand | operation | result | nios2-elf-gcc option | GCC pattern name |
double | none | write X | none | -mcustom-fwrx=N | nios2_fwrx |
float | none | write Y | none | -mcustom-fwry=N | nios2_fwry |
none | none | read low half of X | float | -mcustom-frdxlo=N | nios2_frdxlo |
none | none | read high half of X | float | -mcustom-frdxhi=N | nios2_frdxhi |
none | none | read Y | float | -mcustom-frdy=N | nios2_frdy |
double | double | + | double | -mcustom-faddd=N | adddf3 |
double | double | - | double | -mcustom-fsubd=N | subdf3 |
double | double | * | double | -mcustom-fmuld=N | muldf3 |
double | double | / | double | -mcustom-fdivd=N | divdf3 |
double | double | min | double | -mcustom-fmind=N | mindf3 |
double | double | max | double | -mcustom-fmaxd=N | maxdf3 |
double | none | negation | double | -mcustom-fnegd=N | negdf2 |
double | none | abs | double | -mcustom-fabsd=N | absdf2 |
double | none | sqrt | double | -mcustom-fsqrtd=N | sqrtdf2 |
double | none | cos | double | -mcustom-fcosd=N | cosdf2 |
double | none | sin | double | -mcustom-fsind=N | sindf2 |
double | none | tan | double | -mcustom-ftand=N | tandf2 |
double | none | atan | double | -mcustom-fatand=N | atandf2 |
double | none | exp | double | -mcustom-fexpd=N | expdf2 |
double | none | log | double | -mcustom-flogd=N | logdf2 |
double | double | < | int | -mcustom-fcmpltd=N | nios2_sltdf |
double | double | <= | int | -mcustom-fcmpled=N | nios2_sledf |
double | double | > | int | -mcustom-fcmpgtd=N | nios2_sgtdf |
double | double | >= | int | -mcustom-fcmpged=N | nios2_sgedf |
double | double | == | int | -mcustom-fcmpeqd=N | nios2_seqdf |
double | double | != | int | -mcustom-fcmpned=N | nios2_snedf |
int | none | int to double | double | -mcustom-floatid=N | floatsidf2 |
unsigned | none | unsigned to double | double | -mcustom-floatud=N | floatunssidf2 |
double | none | double to int | int | -mcustom-fixdi=N | fixdfsi2 |
double | none | double to unsigned | unsigned | -mcustom-fixdu=N | fixunsdfsi2 |
float | none | float to double | double | -mcustom-fextsd=N | extendsfdf2 |
double | none | double to float | float | -mcustom-ftruncds=N | truncdfsf2 |
Community support is provided during standard business hours (Monday to Friday 7AM - 5PM PST). Other contact methods are available here.
Intel does not verify all solutions, including but not limited to any file transfers that may appear in this community. Accordingly, Intel disclaims all express and implied warranties, including without limitation, the implied warranties of merchantability, fitness for a particular purpose, and non-infringement, as well as any warranty arising from course of performance, course of dealing, or usage in trade.
