FTA NIos II Verify Fails for System ID and Timestamp
cancel
Showing results for
Search instead for
Did you mean:
363 Discussions
Last Major Update
April 6, 2016
Introduction
Fault Tree Analysis (FTA)is a technique by which conditions and factors that can contribute to a specific issue that are identified and organized in a logical manner and represented pictorially. The main objective of this FTA is to assist in debugging and identifying the root cause of the issue related to Altera Nios II Verify Fails for System ID and Timestamp and resolve the issue effectively.
System ID and Timestamp failures in Nios II is a common issue that user might encounter when developing Nios II designs.
Fault Tree Analysis Diagram & Table
Refer to the link below for: FTA for Nios II Verify Fails for SysID and Timestamp
Click here for: FTA_sysid_and_timestamp [1]
In this FTA, it consists a FTA diagram and table that is used to debug and root cause the system ID and timestamp failure for Nios II systems.
In the FTD, a hypothesis is created based on the failure as described. Each hypothesis can have a second level or more level of suspects. The FTD are then converted to a table to make it easier for the user visually debug the issue.
Disclaimer
© [2013] Altera Corporation. The material in this wiki page or document is provided A-IS and is not supported by Altera Corporation. Use the material in this document at your own risk; it might be for example, objectionable , misleading or inaccurate
Version history
Last update:
‎06-27-2019 12:09 AM
Updated by:
Contributors
