Success! Subscription added.
Success! Subscription removed.
Sorry, you must verify to complete this action. Please click the verification link in your email. You may re-send via your profile.
December 14, 2017
Fault Tree Analysis (FTA)is a technique by which conditions and factors that can contribute to a specific issue that are identified and organized in a logical manner and represented pictorially. The main objective of this FTA is to assist in debugging and identifying the root cause of some of the issues related to Qsys Pro and resolve the issue effectively.
Qsys Pro failures in Nios II is a common issue that user might encounter when developing Nios II designs.
Refer to the link below for: FTA for Nios II Qsys Pro
Click here for: FTA_niosii_qsyspro [1]
In this FTA, it consists a FTA diagram and table that is used to debug and root cause Qsys Pro failure for Nios II systems.
In the FTD, a hypothesis is created based on the failure as described. Each hypothesis can have a second level or more level of suspects. The FTD are then converted to a table to make it easier for the user visually debug the issue.
© [2013] Altera Corporation. The material in this wiki page or document is provided A-IS and is not supported by Altera Corporation. Use the material in this document at your own risk; it might be for example, objectionable , misleading or inaccurate.
Community support is provided during standard business hours (Monday to Friday 7AM - 5PM PST). Other contact methods are available here.
Intel does not verify all solutions, including but not limited to any file transfers that may appear in this community. Accordingly, Intel disclaims all express and implied warranties, including without limitation, the implied warranties of merchantability, fitness for a particular purpose, and non-infringement, as well as any warranty arising from course of performance, course of dealing, or usage in trade.
