cancel
Showing results for
Search instead for
Did you mean:
GPON Example Power Estimation
This design interfaces to four optical modules and performs the packet processing and traffic management of a GPON network. A block diagram of the design is shown below:
3/34/GPON.JPG ( GPON.JPG - click here to view image )
Both resource utilization and frequency of 245MHz were input into the Arria V PowerPlay Early Power Estimator. Design specifications for this Arria V FPGA implementation are as follows:
Resource utilization used in the Arria V PowerPlay Early Power Estimator
Resource Type
Approximate Count
Logic
162 K LUTs
Flip Flops
131 K
Memory
14 Mbits
DSP Blocks
12 blocks in 18bit full precision
IO
400 IO
Transceivers
8 channels at 2.5Gbps
This GPON system would actually sit in a rack, and therefore, a Commercial temperature grade would be the correct temperature grade to estimate power consumption. In our example, we’ve opted to show our worst case power by forcing the junction temperature to 85C, the maximum allowed in the Commercial speed grade without any airflow or heatsink. In reality, this design would have at least airflow for active cooling and possibly even a heatsink. Changing these operating conditions usually impacts the total power consumption.
File:ArriaV EPE Examples.zip and try out the changes for yourself!
Enter to win an Arria V FPGA Development Kit by submitting your Arria V PowerPlay Early Power Estimator!
Version history
Last update:
‎06-27-2019 03:41 PM
Updated by:
Contributors
