cancel
Showing results for
Search instead for
Did you mean:
Guide to 3C120 with u-boot
Please setup DasUBoot first.
in u-boot dir, put 3C120.h in include/configs/, put 3c120_fpga.h in board/altera/nios2-generic/. Then add an entry 3C120 to the NIOS2_GENERIC list in Makefile.
make 3C120_config
make
You will get u-boot elf and u-boot.bin.
In uClinux-dist, make menuconfig, enable MTD command line partition table parsing,fs jffs2 support,
Add, "MKFS_JFFS2_FLAGS = -l -p -e 128" to your vendor/product Makefile.
Make and the images/rootfs.jffs2 will be built. Copy the rootfs.jffs2 to your tftpboot dir.
1. configure the sof
nios2-configure-sof nios2_linux_3c120_125mhz_top.sof
2. download u-boot elf
nios2-download -g u-boot
nios2-terminal
3. set env
==> setenv ethaddr 08:00:3e:26:0a:5b # set MAC of nios2 board
==> setenv ipaddr 192.168.4.2 # set ip of nios2 board
==> setenv serverip 192.168.4.254 # set to your tftp server
==> saveenv
4. program sof to flash
quartus_cpf -c
nios2_linux_3c120_125mhz_top.sof 3c120.rbf
==> protect off all
==> tftp d1000000 3c120.rbf
==> erase e3500000 +380000
==> cp.b d1000000 e3500000
$filesize
5. program zImage to flash. boot
linux without u-boot.
You may convert an elf
executable to binary for flashing with this command,
nios2-elf-objcopy -O binary
zImage zImage.bin
==> tftp d1000000 zImage.bin
==> erase e2800000 +400000
==> cp.b d1000000 e2800000 $filesize
Copy to Flash... done
6.
close nios2-terminal, disconnect jtag cable, power off and power on, Then the D0 LED will blink slowly, this is the heart-beat of nios2-linux. Reconnect the jtag cable, and start nios2-terminal. You can access the shell of
nios2-linux.
 7. program u-boot to flash, this will overwrite the image we wrote in step 5.
==> tftp d1000000 u-boot
Reboot, then you can access the u-boot prompt.
8. program kernel image to
flash.
==> tftp d1000000 vmImage
==> erase e2900000 +200000
==> cp.b d1000000 e2900000 $filesize
9. program jffs2 to flash
==>tftp d1000000 rootfs.jffs2 rootfs_(2).jffs2
==> erase e0000000 +2800000
==> cp.b d1000000 e0000000 $filesize
10. Set the env as,
==> setenv bootcmd 'set bootargs root=/dev/mtdblock0 rootfstype=jffs2 ip=dhcp;bootm e2900000'
==> saveenv
Boot linux with jffs2
==> run bootcmd
Additional Download
Version history
Last update:
‎06-27-2019 03:48 PM
Updated by:
Contributors
