Success! Subscription added.
Success! Subscription removed.
Sorry, you must verify to complete this action. Please click the verification link in your email. You may re-send via your profile.
Design files is in link below.
Quick Start Guide
1) Replace the Uboot (uboot_w_dtb-mkpimage.bin in /software folder) into SD card A2 partition using dd command (in Linux) or alt-boot-disk-util command in SoC EDS Command Shell (in Windows).
Note: You would need to “Run as administrator” when launching SoC EDS Command Shell in Windows in order to write the Uboot into A2 partition on SD card.
2) Copy and replace the 3 files in sdcard_fat_files folder into the SD card FAT partition.
3) Insert the SD card and let the system boot into Linux.
4) Mount FAT partition of SD card to system (to /mnt folder) with command below.
mount /dev/mmc0p1 /mnt
5) Copy the chipid.sh from /mnt to ~/ directory with command.
cp /mnt/chipid.sh ~/
6) Execute chipid.sh script with command below:
sh chipid.sh
The Chip ID will be printed on Linux UART Console.
7) For Nios II, load the elf file (chip_id.elf in software/chip_id_nios folder) into Nios II by entering command below in Nios II Command Shell
Nios2-download –g chip_id.elf && nios2-terminal
The Chip ID will be printed on Nios II terminal.
Community support is provided Monday to Friday. Other contact methods are available here.
Intel does not verify all solutions, including but not limited to any file transfers that may appear in this community. Accordingly, Intel disclaims all express and implied warranties, including without limitation, the implied warranties of merchantability, fitness for a particular purpose, and non-infringement, as well as any warranty arising from course of performance, course of dealing, or usage in trade.
