Success! Subscription added.
Success! Subscription removed.
Sorry, you must verify to complete this action. Please click the verification link in your email. You may re-send via your profile.
For those who do not want to use Eclipse for your Nios2 debugging needs and prefer a debugger you can launch from the command line, Insight may be a good solution. Insight 6.1 was inluded in all the Nios2 release the were based upon the gnu 3.xx version. In 10.1 Altera switch to a later release 4.1.2. By default GNU 4.xx does not include Insight. However insight 6.8 can be downloaded from the web patched and build for the nios. The instruction below show you how to do it.
The GNU Insight build does not work with 3.81 of the make tool. It will die when compiling bfd/dwarf2.c. This is due to a parameter which must be quoted. Versions 3.80 and 3.82 work. To see which version you have type
make -version
in a Nios2 command shell. If the version is 3.81 it is probably the make in the nios2eds path. To check type
which make
There are 2 make.exe in the quartus installs One in $SOPC_KIT_NIOS2/bin/gnu/H-i686-mingw32/bin/make and $QUARTUS_ROOT_DIR/bin/cygwin/bin. The default path uses the make.exe from the nios2eds path ahead of of the cygwin path. To use the other make.exe simply rename the make.exe in the offending path -- but don't forget to change it back. Or you can change the paths temporarily. With the correct make.exe you are read to build.
ES: I was not successful with this and I just had to call /usr/bin/make to force the correct version.
ES: Note: I am no longer able to compile insight on Quartus 12.1. It appears that some of the cygwin components may have upgrades and the tcl support is no longer building.
Create a new directory i.e. "Insight" and download the source to it.
Note: any directory name will be fine just avoid spaces and special chars in the path name
ftp://sourceware.org/pub/insight/releases
The patches have been tested with Insight-6.8a and insight-6.8-1a
Open a nios2 command shell and change the directory to the "Insight" directory and un-tar the downloaded file
tar xvjf insight-6.8(-1)a.tar.bz2 (-1 is only used with the 6.8-1 source)
this will create an insight-6.8* subdirectory
cd insight-6.8
copy the nios2-insight_patches.zip to the insight-6.8* subdirectory and unzip. This will create a nios2-insight6.8_patches sub folder. Make sure that you didn't accidentally create and extra fold.
cd nios2-insight6.8_patches
run
./apply_patches
A list of patched and moved files should appear with no errors
cd ../../
Go back up two levels so back to the "Insight" directory type the following commands
mkdir build
.../insight-6.8a/configure --target=nios2-elf
make
ES: I just went back to the main insight-6.8a directory and called ./configure --target=nios2-elf
ES: As noted above, from the insight-6.8a directory, I called /usr/bin/make instead of make to launch the correct version
ES: This worked for me in Quartus 11, but no longer works in Quartus 12
make install
This will build and install the tools at $quartus_rootdir/bin/cygwin/usr/local/bin
to run Insight place the nios2-debug1 script somwhere in the the path like
c:/altera/x.x/nios2eds/bin
There is already a nios2-debug script so 1 one was appended to the end
Note: remove the .txt from the nios2-debug you download from this site.
Now you are ready to run. From the directory where the elf is located run
nios2-debug1 <project>.elf
if you are using ucsoii and you want thread awareness
nois2-debug1 -ucosii <project>.elf
File:Nios2 insight-6.8 patches.zip
File:InsightQuartus12 1 merge.zip
Create binarys that be installed.
Learn how to install in different directories.
Community support is provided Monday to Friday. Other contact methods are available here.
Intel does not verify all solutions, including but not limited to any file transfers that may appear in this community. Accordingly, Intel disclaims all express and implied warranties, including without limitation, the implied warranties of merchantability, fitness for a particular purpose, and non-infringement, as well as any warranty arising from course of performance, course of dealing, or usage in trade.
