cancel
Showing results for
Search instead for
Did you mean:
Internal Host Partial Reconfiguration Using Flash
This is a PR example design developed on Stratix V FPGA Dev Kit using ACDS 13.1.
  • Internal host with bitstreams in Flash
  • Static region:
  • Nios II program PR bitstream into external flash
  • One PR region containing 2 personas:
  • Persona 1: Green LED scrolling
  • Persona 2: Red LED scrolling
Media:internal_pr.zip
Out of Box Experience
  • The attached design is ready with compiled sof file and rbf file for each persona, if you want to hands on directly, skip to program the sof and flash. If you recompile the design, you might want to regenerate the updated rbf for the persona:
To generate the .rbf file, you can use the Nios command shell or in Quartus (File -> Convert Programming Files)
  • Generate .pmsf file from .sof and .msf files
quartus_cpf -p output_files/s5gxea7_fpga_bup.x3y5.msf output_files/s5gxea7_fpga_bup.sof output_files/base.pmsf
quartus_cpf -p output_files/pr_0.x3y5.msf output_files/pr_0.sof output_files/reconfig.pmsf
  • Generate .rbf files from .pmsf files
quartus_cpf -c output_files/base.pmsf output_files/base.rbf
quartus_cpf -c output_files/reconfig.pmsf output_files/reconfig.rbf
  • Convert .rbf files to .flash files
bin2flash --input=output_files/base.rbf --output=output_files/base.flash --location=0x021C0000
bin2flash --input=output_files/reconfig.rbf --output=output_files/reconfig.flash --location=0x023C0000
  • Program the sof into the board
nios2-configure-sof output_files/s5gxea7_fpga_bup.sof
  • Program the flash before you run the partial reconfiguration. Use Nios Command Shell:
nios2-flash-programmer --base=0x0 --program output_files/base.flash
nios2-flash-programmer --base=0x0 --program output_files/reconfig.flash
  • Select the persona using dip_switch[0], then press button (PB2) to start the PR
0x0: Persona 1: Green LEDs scrolling
0x1: Persona 2: Red LEDs scrolling
  • Other LEDs:
LED7: blinking to show static region is running during PR process
Version history
Last update:
‎06-21-2019 07:24 PM
Updated by:
Contributors
