cancel
Showing results for
Search instead for
Did you mean:
JFFS2 for Linux
JFFS2 for Linux
 In the Linux Kernel configuration, JFFS2 Support depends on:
  • Memory Technology Devices Support (MTD)
  • Miscellaneous File Systems
Packages needed for building jffs2
To build jffs2 support for Linux, the following libraries must be installed on your Linux desktop:
  • zlib-devel
  • lzo-devel
You will need to define your flash partitions in the variable "static struct mtd_partition nios2_partitions" in arch/nios2/kernel/config.c. Also, make sure you are defining the correct flash width in "static struct physmap_flash_data nios2_flash_data" in the same file.
Version history
Last update:
‎06-21-2019 08:03 PM
Updated by:
Contributors
