JTAG Constraints file in Timing Analyzer Cookbook MNL-010135
cancel
Showing results for
Search instead for
Did you mean:
340 Discussions
  • Description: This forum article is dedicated to help users that are trying to copy and paste Example 21: JTAG Signal Constraints from the Intel Quartus Prime Timing Analyzer Cookbook.
  • This article refers to Example 21: JTAG Signal Constraints from the Intel Quartus Prime Timing Analyzer Cookbook, MNL-01035:
             https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/mnl_timequest_cookbook.pdf
           -   Refer to the attached file jtag_constraints.sdc (rename from jtag_constraints.txt) and then can be referenced from the project qsf file.
set_global_assignment -name SDC_FILE jtag_constraints.sdc
       -    Remember to look at all sections that have “---customize here---” to change parameters based on location of the FPGA in the JTAG chain, JTAG speed, and board layout.
Version history
Last update:
‎06-17-2020 04:52 PM
Updated by:
Contributors
