cancel
Showing results for
Search instead for
Did you mean:
Linux Desktop Install
If you are new to Linux, it is suggested that you start with Centos5 i386 32bit distro.You may find a step by step guide on Linux installation and usage from Redhat's doc or Centos' doc.
Install the required development packages on your Linux desktop, as root or sudo,
RHEL5/Centos5
For RHEL5/Centos5, enable EPEL at https://fedoraproject.org/wiki/EPEL.
# for RHEL5/Centos5 only
wget http://mirror.metrocast.net/fedora/epel/5/i386/epel-release-5-4.noarch.rpm
rpm -Uvh epel-release-5-4.noarch.rpm
# for RHEL5/Centos5
yum install git-all git-gui tcsh make gcc ncurses-devel bison libglade2-devel \
byacc flex gawk gettext ccache zlib-devel gtk2-devel lzo-devel pax-utils e2fsprogs e2fsprogs-devel
#get the initial git files - This gets a bunch of tar files so they are not too big...
wget ftp://ftp.altera.com/outgoing/nios2-linux/20120802/* .
#check that they are right
md5sum --check files.md5sum
#extract the files - they will extract into a directory called nios2-linux
for i in $(ls nios2-linux-*.tgz); do tar -xzvf $i;done
#This should download the following
# ftp://ftp.altera.com/outgoing/nios2-linux/20120802/files.md5sum
# ftp://ftp.altera.com/outgoing/nios2-linux/20120802/nios2-linux-3c120_default-20120802.tgz
# ftp://ftp.altera.com/outgoing/nios2-linux/20120802/nios2-linux-base-20120802.tgz
# ftp://ftp.altera.com/outgoing/nios2-linux/20120802/nios2-linux-binutils-20120802.tgz
# ftp://ftp.altera.com/outgoing/nios2-linux/20120802/nios2-linux-boards-20120802.tgz
# ftp://ftp.altera.com/outgoing/nios2-linux/20120802/nios2-linux-elf2flt-20120802.tgz
# ftp://ftp.altera.com/outgoing/nios2-linux/20120802/nios2-linux-gcc3-20120802.tgz
# ftp://ftp.altera.com/outgoing/nios2-linux/20120802/nios2-linux-glibc-20120802.tgz
# ftp://ftp.altera.com/outgoing/nios2-linux/20120802/nios2-linux-insight-20120802.tgz
# ftp://ftp.altera.com/outgoing/nios2-linux/20120802/nios2-linux-linux-2.6-20120802.tgz
# ftp://ftp.altera.com/outgoing/nios2-linux/20120802/nios2-linux-openip-20120802.tgz
# ftp://ftp.altera.com/outgoing/nios2-linux/20120802/nios2-linux-toolchain-build-20120802.tgz
# ftp://ftp.altera.com/outgoing/nios2-linux/20120802/nios2-linux-toolchain-mmu-20120802.tgz
# ftp://ftp.altera.com/outgoing/nios2-linux/20120802/nios2-linux-tools-20120802.tgz
# ftp://ftp.altera.com/outgoing/nios2-linux/20120802/nios2-linux-u-boot-20120802.tgz
# ftp://ftp.altera.com/outgoing/nios2-linux/20120802/nios2-linux-uClibc-20120802.tgz
# ftp://ftp.altera.com/outgoing/nios2-linux/20120802/nios2-linux-uClinux-dist-20120802.tgz
# For mmu-less nios2 uCLinux, download the precompiled toolchain as well
wget ftp://ftp.altera.com/outgoing/nios2-linux/nios2gcc-20080203.tgz
#this extracts to nios2-gcc3, so if you want it in the nios2-linux dir add -C ./nios2-linux to the extract command
tar -xzvf nios2gcc-20080203.tgz
Fedora
#for Fedora
byacc flex gawk gettext ccache zlib-devel gtk2-devel lzo-devel pax-utils libuuid libuuid-devel
Fedora 17 USB Blaster udev rule
save this to /etc/udev/rules.d/51-usbblaster.rules
# USB-Blaster
SUBSYSTEM=="usb", ATTR{idVendor}=="09fb", ATTR{idProduct}=="6001", MODE="0666", SYMLINK+="usbblaster-%k"
SUBSYSTEM=="usb", ATTR{idVendor}=="09fb", ATTR{idProduct}=="6002", MODE="0666", SYMLINK+="usbblaster-%k"
SUBSYSTEM=="usb", ATTR{idVendor}=="09fb", ATTR{idProduct}=="6003", MODE="0666", SYMLINK+="usbblaster-%k"
#USB-Blaster II
SUBSYSTEM=="usb", ATTR{idVendor}=="09fb", ATTR{idProduct}=="6010", MODE="0666", SYMLINK+="usbblasterii-%k"
SUBSYSTEM=="usb", ATTR{idVendor}=="09fb", ATTR{idProduct}=="6810", MODE="0666", SYMLINK+="usbblasterii-%k"
Updated for Fedora 18 -
SUBSYSTEM=="usb", ATTR{idVendor}=="09fb", ATTR{idProduct}=="6001", MODE="0666", SYMLINK+="usbblaster/%k"
SUBSYSTEM=="usb", ATTR{idVendor}=="09fb", ATTR{idProduct}=="6002", MODE="0666", SYMLINK+="usbblaster/%k"
SUBSYSTEM=="usb", ATTR{idVendor}=="09fb", ATTR{idProduct}=="6003", MODE="0666", SYMLINK+="usbblaster/%k"
# USB-Blaster II
SUBSYSTEM=="usb", ATTR{idVendor}=="09fb", ATTR{idProduct}=="6010", MODE="0666", SYMLINK+="usbblaster2/%k"
SUBSYSTEM=="usb", ATTR{idVendor}=="09fb", ATTR{idProduct}=="6810", MODE="0666", SYMLINK+="usbblaster2/%k"
Also see How to set up OpenSUSE11.2 for NIOS2 Linux.
Next step: Download Linux distribution for the Nios II processor
Version history
Last update:
‎06-25-2019 11:30 PM
Updated by:
Contributors
