cancel
Showing results for
Search instead for
Did you mean:
Linux Hwselect
Linux Hwselect
0 / 5 (0 votes cast)
The hwselect script will prepare the headers of the memory and io port maps of your board.
Change to the uClinux-dist directory
make vendor_hwselect SYSPTF=/path_to/your_sytem.ptf # this is instead of make hwselect
If you change the ptf later, you may have to make clean the kernel dir. Then run make vendor_hwselect SYSPTF=/path_to/your_sytem.ptf again.
If you use Altera Nios II dev boads, look for the (any) .ptf and .sof in dir, /opt/altera8.0/nios2eds/examples/verilog/ , e.g. If you use Altera Cyclone II Nios dev board with 2C35, the .ptf file is:
/opt/altera8.0/nios2eds/examples/verilog/niosII_cycloneII_2c35/full_featured/NiosII_?cycloneII_2c35_full_featured_sopc.ptf
and the .sof is
NiosII_cycloneII_2c35_full_featured.sof
The ptf must match your board and the sof.
If you use DE2, look in DE2 support CD:
DE2_System/DE2_demonstrations/DE2_NET/ nios_0.ptf and DE2_NET.sof
(look for *.ptf, the filename may change)
You should select a Nios2 cpu, and sdram/ddr/ddr2_sdram. Your memory size should be at least 8MB.
Here is the example of NEEK,
RUNNING hwselect
--- Please select which CPU you wish to build the kernel against:
(1) cpu - Class: altera_nios2 Type: f Version: 7.071
Selection: 1
--- Please select a device to execute kernel from:
(1) ext_flash
Class: altera_avalon_cfi_flash
(2) ssram
Class: altera_avalon_cy7c1380_ssram
(3) ddr_sdram
Class: ddr_high_perf
Selection: 3
--- Summary using
PTF: /home/hippo/boards/ocm/cycloneIII_embedded_evaluation_kit_standard_sopc.ptf
CPU: cpu
Program memory to execute from: ddr_sdram
--- Settings written to /home/hippo/nios2-linux/uClinux-dist/linux-2.6.x/arch/nios2/hardware.mk
When you compile the kernel, file linux-2.6.x/include/asm-nios2/nios2.h will be generated. It contains the memory and io ports address of your board.
Version history
Last update:
‎06-24-2019 08:43 PM
Updated by:
Contributors
