Success! Subscription added.
Success! Subscription removed.
Sorry, you must verify to complete this action. Please click the verification link in your email. You may re-send via your profile.
To build net-snmp, please enter apps config,
Network Applications --->
[*] net-snmp
[*] Build mini agent
[ ] Build Applications (NEW)
[*] Build static /* select this only if NOMMU */
[ ] Install manuals (NEW)
[ ] Install scripts (NEW)
[*] Install MIBs
[ ] Enable MIB loading (NEW)
[ ] Disable SNMP v1 (NEW)
[ ] Disable SNMP v2c (NEW)
[ ] IPv6 support (NEW)
[ ] Exclude transports (NEW)
[ ] With OpenSSL (NEW)
[ ] Override defaults (NEW)
[ ] Additional MIBS (NEW)
Create a snmpd.conf to romfs/etc/snmp/snmpd.conf, with single line,
rwcommunity public
Boot your nios2 board, config ethernet. Then start snmpd,
> snmpd -c public &
Query the nios2 board from another Linux box with net-snmp installed:
$ snmpwalk -v 1 -c public 172.20.11.51 system
SNMPv2-MIB::sysDescr.0 = STRING: uClinux uClinux 2.6.23-uc0-gb13c4d1f-dirty #138 PREEMPT Wed Mar 5 12:48:49 MST 2008 nios2nommu
SNMPv2-MIB::sysObjectID.0 = OID: NET-SNMP-MIB::netSnmpAgentOIDs.10
DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (80124) 0:13:21.24
SNMPv2-MIB::sysContact.0 = STRING: jchen@
SNMPv2-MIB::sysName.0 = STRING: uClinux
SNMPv2-MIB::sysLocation.0 = STRING: Unknown
SNMPv2-MIB::sysORLastChange.0 = Timeticks: (16) 0:00:00.16
SNMPv2-MIB::sysORID.1 = OID: IF-MIB::ifMIB
SNMPv2-MIB::sysORID.2 = OID: SNMPv2-MIB::snmpMIB
SNMPv2-MIB::sysORID.3 = OID: TCP-MIB::tcpMIB
SNMPv2-MIB::sysORID.4 = OID: IP-MIB::ip
SNMPv2-MIB::sysORID.5 = OID: UDP-MIB::udpMIB
SNMPv2-MIB::sysORID.6 = OID: SNMP-VIEW-BASED-ACM-MIB::vacmBasicGroup
SNMPv2-MIB::sysORID.7 = OID: SNMP-FRAMEWORK-MIB::snmpFrameworkMIBCompliance
SNMPv2-MIB::sysORID.8 = OID: SNMP-MPD-MIB::snmpMPDCompliance
SNMPv2-MIB::sysORID.9 = OID: SNMP-USER-BASED-SM-MIB::usmMIBCompliance
SNMPv2-MIB::sysORDescr.1 = STRING: The MIB module to describe generic objects for network interface sub-layers
SNMPv2-MIB::sysORDescr.2 = STRING: The MIB module for SNMPv2 entities
SNMPv2-MIB::sysORDescr.3 = STRING: The MIB module for managing TCP implementations
SNMPv2-MIB::sysORDescr.4 = STRING: The MIB module for managing IP and ICMP implementations
SNMPv2-MIB::sysORDescr.5 = STRING: The MIB module for managing UDP implementations
SNMPv2-MIB::sysORDescr.6 = STRING: View-based Access Control Model for SNMP.
SNMPv2-MIB::sysORDescr.7 = STRING: The SNMP Management Architecture MIB.
SNMPv2-MIB::sysORDescr.8 = STRING: The MIB for Message Processing and Dispatching.
SNMPv2-MIB::sysORDescr.9 = STRING: The management information definitions for the SNMP User-based Security Model.
SNMPv2-MIB::sysORUpTime.1 = Timeticks: (3) 0:00:00.03
SNMPv2-MIB::sysORUpTime.2 = Timeticks: (6) 0:00:00.06
SNMPv2-MIB::sysORUpTime.3 = Timeticks: (6) 0:00:00.06
SNMPv2-MIB::sysORUpTime.4 = Timeticks: (6) 0:00:00.06
SNMPv2-MIB::sysORUpTime.5 = Timeticks: (6) 0:00:00.06
SNMPv2-MIB::sysORUpTime.6 = Timeticks: (7) 0:00:00.07
SNMPv2-MIB::sysORUpTime.7 = Timeticks: (16) 0:00:00.16
SNMPv2-MIB::sysORUpTime.8 = Timeticks: (16) 0:00:00.16
SNMPv2-MIB::sysORUpTime.9 = Timeticks: (16) 0:00:00.16
Community support is provided during standard business hours (Monday to Friday 7AM - 5PM PST). Other contact methods are available here.
Intel does not verify all solutions, including but not limited to any file transfers that may appear in this community. Accordingly, Intel disclaims all express and implied warranties, including without limitation, the implied warranties of merchantability, fitness for a particular purpose, and non-infringement, as well as any warranty arising from course of performance, course of dealing, or usage in trade.
