cancel
Showing results for
Search instead for
Did you mean:
New Qsys Issues
New Qsys Issues
4 / 5 (1 vote cast)
 Overview
The purpose of this page is to keep an active list of Qsys issues and workarounds over the first few releases of the tool in the Quartus II software.
Before adding to this page please review the following documents to learn more about Qsys or the known issues list:
If you find an issue, please file a service request at mysupport so that it can be tracked and addressed by Altera:  http://www.altera.com/mysupport
Formatting
If you find a new issue please add it to the list below by editing this page so that others can benefit from it as well. So that the formatting will be consistent, please use the Issue:Workaround format and provide short descriptive titles using the "Heading 3" format under the appropriate New Issues section.
New Issues
Qsys Editor (UI) Issues
Issue: Qsys doen't remember the user-entered IP search path (Tools -> Options ). Adding the user_components.ipx as described on page 5-13 (Quartus II Handbook Version 12.0) doesn't work either. This usually occurs when launching Qsys outside a Quartus II project. The path used (in 13.0 sp1) appears to be based on the path to the QSYS file that is currently open, and not on the user's path configuration. I also observe that paths in project specific xxx.ipx files are used when qsys-edit is first run, but they are later forgotten when QSYS opens a source file (13.0 sp1).
  Workaround: add a <Path path=... /> entry into the main <$QUARTUS_INSTALLDIR>/sopc_builder/bin/root_components.ipx file.  Fixed in Quartus II 12.1 (The problem is observed to remain in 13.0 sp1)
Issue: Qsys Component Editor can't handle SystemVerilog packages in the top level file. Use of packages ("import mypackage::*;") causes the Component Editor to fail to find any modules.
Version history
Last update:
‎06-27-2019 07:54 PM
Updated by:
Contributors
