cancel
Showing results for
Search instead for
Did you mean:
Nios II Embedded Evaluation Kit
If so, then this page is dedicated to you.Are you the proud owner of the Nios II Embedded Evaluation Kit, Cyclone III Edition?
  • Download way cool new demos on your SD Card!
  • Download hardware designs and source code for new designs
  • Post your own designs, tips and documents for the Nios II Embedded kit
Begginners Corner
Embedded Systems on FPGAs give so much more control and power over your design that this quickly becoming a the platform on choice for developing embeddedsystems. But if you find you are not aFPGA guruthen dont worry, takebaby steps.
  • Nios II Standard Processor System
    • Dont create a Nios II processor system for your UNEEK from scratch. This is a "starter" Nios II processor system that has already been put together for you using SOPC Builder. This is the processor system that boots up on your NEEK by default on power on. You can go ahead and start developing your own software application starting with a blank project or take the "My first Nios II Software Application" tutorial below. If you want to addormodifythisprocessor system then simply open it in SOPC Builder andget started.
  • My First Nios II Software Application Tutorial
    • New towriting software for Nios II processor?Take this simple software tutorial thatwill show you how to blink an LED. You willget a hang of some the basicsoftware developmentflow. Have patience and remember: Ajourney of a thousand lines of code begins by blinking a single LED.
Developers Zone
Full system designs build upon Nios II processor systems by providing a software application to go with the processor system. Usually the software is application focussed i.e. does something useful.By refering to the sourcecode for these applications isa great way to see exampleof software drivers for varioushardware peripherals onyour board.
  • Altera's Video and Image Processing Suite Demo on the NEEK
    • See Altera's Video and Image Processing Suite running on the Nios II Embedded Evaluation Kit
  • MP3 Player
    • Touch-screen MP3 player example for the Nios II Embedded Evaluation kit.
  • VGA Application Selector Updater
    • Now that you have the awesome Nios II Embedded Evaluation Kit, you are going to need to show off the cool demos that you and others have built to your friends and co-workers. Do it in a big way;USE A PROJECTOR!Simply download the updater to your kit, attach a VGA cable and off you go!
  • Application Selector Utility
    • This handy dandy utility is the 'user interface' for the Nios II Embedded Evaluation Kit. With this design you can use the LCD touch panel to scroll through a list of designs stored on the SD Card and load your design of choice. (See VGA Application Selector Updater to get a VGA compatible version of Application Selector)
  • Mandelbrot C2H Hardware Acceleration
    • The Mandelbrot is an organically beautiful pattern with seemingly infinite variation! The demo however, is more than just a pretty picture: the Nios II C to Hardware (C2H) Compiler has been used to accelerate the Mandelbrot algorithm in hardware performingbillions of computations a second!
  • Web Server/Remote FPGA Configuration
    • This design examples shows an HTTP web server application using the sockets interface of the TCP/IP Stack-Nios®II Editionon MicroC/OS-II to serve web content from your NEEK. The server can process basic requests to serve HTML, JPEG, and GIF files from the Altera®read-only.zipfile system or File Allocation Table (FAT) file system. Additionally, it demonstrates remote configuration over Ethernet to allow you to change the hardware and software configuration of the FPGA.
  • Remote System Update
    • Did you know:Your NEEK is capable of running a web server that allows you to browse your PC for an FPGA image and reconfigure your board with a new FPGA image:allaccomplished over Ethernet.Findoutmore.
  • UNEEK Picture Viewer (v8.0 SP1 Now Available)
    • Built upon the Nios II Standard Processor System, this application takes JPEG images or bitmaps stored on the SD Card and displays them on the LCD Touch Panel.
Evaluators Zone
Decisions, decisions. What's a good operating system for mynext application? Where can I findIP for my Nios II processor system?Here's something thatwill ease the evaluatorsdilemma.
Ready to Run Demos: A Ready to Run demo is a quick and easy way to demonstrate and evaluate an implementation of a commercialapplicationsuch as automotive graphics,consumer GUI, industrial control. These demoscan beeasily selected andloaded using the application selector on your LCD touch panel. These demos are provided for demonstration and evaluation purposes. They are providedby Altera and Altera's partners to showcase commercial gradeoperating systems, middleware,IP and software tools.
So if you are looking to select a suitable operating system (e.g. Micriums uC-OS II or SLS's port of uC-Linux for Nios II), IP Cores (from simply SD Card cores to high performance Vector graphics engines), middleware librarys (Networks Stacks, Graphics Library) or graphics development tools ( PlanetWebSpectraWorks, Altia Design) then you Ready to Run demos help you make your evaluation processor fun and easy.
Ready to Run demos are provided in binary format only (.FLASH), full Quartus II projects, source code, IP licensing etc can be obtained by contacting the provider of the Ready to Run demo
  • SpectraWorks Digital Photo Frame
    • Simply take your favorite JPEG Photos and watch them in your very own electronic photo album. This application , built using the amazing Spectraworks user interface platform displays your photos wither as a thumbnail or as a user configurable slideshow. Basic features include support for multiple albums, zoom, pan, rotate, transition effects and more.
  • Planetweb SpectraWorks GUI Demo
    • What is the first thing you would like to see on this demo? >HelloWorld?
    • Or... Fabulous graphics and beautiful anti-aliased text!
    • Based on the SpectraWorks User Interface platform from Planetweb see examples of smooth animation, beautiful test in multiple typefaces, dynamically scalable widgets and the ability to re-skin any application without making any changes to the source code!
  • Technology Demo
    • Evaluate Imagems Graphics and video capabilities in the most fun way possible;Play the game Tacquin!
    • Tacquinis a puzzle that you solve by touching squares on the LCD touch panel.
    • You can use your favorite pic or evenLive Videoas the puzzle
  • D/AVE Graphics Accelerator Demo
    • Astonishing automotive demos using the TES D/AVE Graphics Accelerator. Witness first hand the power of hardware acceleration as the innovative rendering engine D/AVE IP performs Anti-Aliasing with Subpixel Accuracy, vector graphics, additive blending and much more.
Design examples available for download from the community
See Try Out uClinuxto find a Linux distribution bootable from the SD-Card.
Disclaimer
Coffre-fort agréé Coffre-fort A2P Coffre-fort agréé www.credits-immobilier.org http://www.geeksandthecity.fr
Version history
Last update:
‎06-25-2019 09:17 PM
Updated by:
Contributors
